Conditionalize make behavior e.g. disable --gc-sections
dufault at hda.com
dufault at hda.com
Fri May 10 12:27:41 UTC 2019
> On May 10, 2019, at 08:07 , Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
> On 10/05/2019 13:58, Gedare Bloom wrote:
>> On Tue, May 7, 2019 at 5:03 AM Peter Dufault<dufault at hda.com> wrote:
>>> What is best practice to change build behavior? e.g. I need to use --whole-archive/--no-whole-archive in one place but --gc-sections breaks it and that's turned on for the BSP (xilinx_zynq_a9_qemu).
>>> I’ve done this in the .cfg files for the BSP:
>>> ifneq ($(RTEMS_GC_SECTIONS_DISABLE),1)
>>> LDFLAGS_GC_SECTIONS_DISABLE = -Wl,--gc-sections
>>> endif
>>> LDFLAGS = $(LDFLAGS_GC_SECTIONS_DISABLE)
>>> and then I set RTEMS_GC_SECTIONS_DISABLE=1 in the one Makefile where I need it. I don’t see similar patterns, is this the way to do it?
>> Historically a new BSP variant has been introduced when there needs to
>> be a change at this .cfg level. But, I could see a rationale to
>> include this kind of switching behavior at a higher level. Someone
>> might consider how to integrate it into our configure.ac/Makefile.am
>> black magic, but that is beyond me:).
>> An alternative approach that may work from what you propose is to use
>> following in the xilinx zynq .cfg file:
>> LDFLAGS ?= -Wl, --gc-sections
>> then, you can provide own LDFLAGS = -Wl on your make command line or
>> in your Makefile, I think that would work bit more elegant
> Nobody forces you to use -Wl, --gc-sections to link your application. For the RTEMS tests and samples this shouldn't be an issue?
My make pulls in those settings. I think it is best to use the same settings that the RTEMS tests and samples unless I have a good reason to change them, e.g., I need —whole-archive in one application in one place.
What do you recommend? Where is an example to build from?
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
This email is delivered through the public internet using protocols subject to interception and tampering.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190510/49f88867/attachment.html>
