[PATCH] shell: Avoid rtems_error()
Sebastian Huber
Fri May 10 12:40:58 UTC 2019
Do not use the rtems_error() function since this function pulls in
exit() and abort(). The abort() function pulls in raise() which pulls
in the whole POSIX signals support. This change saves about 16KiB of
text/rodata on ARM Thumb-2 systems.
cpukit/libmisc/shell/shell.c | 9 ---------
1 file changed, 9 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 812a0b02bf..c2ea3c4afa 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -20,7 +20,6 @@
#include <time.h>
-#include <rtems/error.h>
#include <rtems/libio.h>
#include <rtems/libio_.h>
#include <rtems/shell.h>
@@ -689,7 +688,6 @@ static bool rtems_shell_init_user_env(void)
/* Make sure we have a private user environment */
sc = rtems_libio_set_private_env();
if (sc != RTEMS_SUCCESSFUL) {
- rtems_error(sc, "rtems_libio_set_private_env():");
return false;
@@ -730,18 +728,15 @@ bool rtems_shell_main_loop(
shell_env = rtems_shell_init_env(shell_env_arg);
if (shell_env == NULL) {
- rtems_error(0, "rtems_shell_init_env");
return false;
eno = pthread_setspecific(rtems_shell_current_env_key, shell_env);
if (eno != 0) {
- rtems_error(0, "pthread_setspecific(shell_current_env_key)");
return false;
if (!rtems_shell_init_user_env()) {
- rtems_error(0, "rtems_shell_init_user_env");
return false;
@@ -997,14 +992,11 @@ static rtems_status_code rtems_shell_run (
&task_id
- rtems_error(sc,"creating task %s in shell_init()",task_name);
return sc;
shell_env = rtems_shell_init_env( NULL );
if ( !shell_env ) {
- rtems_error(RTEMS_NO_MEMORY,
- "allocating shell_env %s in shell_init()",task_name);
return RTEMS_NO_MEMORY;
shell_env->devname = devname;
@@ -1025,7 +1017,6 @@ static rtems_status_code rtems_shell_run (
sc = rtems_task_start(task_id, rtems_shell_task,
(rtems_task_argument) shell_env);
- rtems_error(sc,"starting task %s in shell_init()",task_name);
return sc;
2.16.4
