GSoC Project | Basic Support for Trace Compass
Tue May 14 07:15:34 UTC 2019
On 14/05/2019 08:34, Ravindra Kumar Meena wrote:
> On Tue, May 14, 2019 at 11:24 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 13/05/2019 08:24, Ravindra Kumar Meena wrote:
>     > *The goal of this week:*
>     > The goal of phase 1 of my GSoC proposal is to generate the trace
>     > data(LTTng) in Common Trace Format(CTF) from target running RTEMS
>     > application. The Event Recording infrastructure lacks the
>     generation
>     > of trace data in Common Trace Format(CTF). I will try to figure
>     out a
>     > convenient method for it.
>     Please note that there are at least two options where you can do the
>     conversion, you can do the conversion on the target or you can do the
>     conversion on the host.
> In my point of view, the conversion should take place on the host side
> because the host is more powerful. It would reduce the conversion time.
Yes, I would try this a approach first. However, please keep in mind
that RTEMS runs also on 1.5GHz chips with 24 cores. This means the
conversion must be fast also on a modern host computer if you want to
support the high end RTEMS systems.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
