Build FreeBSD: FAILED 5/rtems-epiphany.bset on x86_64-freebsd12.0 (epiphany-rtems5-gdb-7.8.1-x86_64-freebsd12.0-1)
Wed May 15 03:17:11 UTC 2019
On 14/5/19 11:26 pm, Sebastian Huber wrote:
> The GDB build on FreeBSD 12 fails here:
> + /usr/local/bin/unzip -u
> /usr/home/user/rtems-source-builder/rtems/sources/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
> /usr/home/user/rtems-source-builder/rtems/build/epiphany-rtems5-gdb-7.8.1-x86_64-freebsd12.0-1/do-build:
> /usr/local/bin/unzip: not found
> I have it installed here:
> $ which unzip
> /usr/bin/unzip
Fixed with https://lists.rtems.org/pipermail/vc/2019-May/016129.html
Thanks
