Build FreeBSD: FAILED 5/rtems-epiphany.bset on x86_64-freebsd12.0 (epiphany-rtems5-gdb-7.8.1-x86_64-freebsd12.0-1)
Wed May 15 05:13:19 UTC 2019
On 15/05/2019 05:17, Chris Johns wrote:
> On 14/5/19 11:26 pm, Sebastian Huber wrote:
>> The GDB build on FreeBSD 12 fails here:
>> + /usr/local/bin/unzip -u
>> /usr/home/user/rtems-source-builder/rtems/sources/f05996c7c42e6b2781946acbab153a481ce3fd0b.zip
>> /usr/home/user/rtems-source-builder/rtems/build/epiphany-rtems5-gdb-7.8.1-x86_64-freebsd12.0-1/do-build:
>> /usr/local/bin/unzip: not found
>> I have it installed here:
>> $ which unzip
>> /usr/bin/unzip
> Fixed with https://lists.rtems.org/pipermail/vc/2019-May/016129.html
Thanks, it works:
https://lists.rtems.org/pipermail/build/2019-May/002364.html
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
