fatal after a new source-builder update
Ярослав Лещинский
midniwalker at gmail.com
Wed May 15 13:31:32 UTC 2019
problem solved after edition of CPU_FLAGS as mentioned in stm32f4.cfg:
CPU_FLAGS = -mthumb -mcpu=cortex-m4
Thanks.
On Wed, 15 May 2019 at 09:41, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> Ok, I will check.
> Thanks.
> ср, 15 мая 2019 г. в 9:34, Sebastian Huber <
> sebastian.huber at embedded-brains.de>:
>> On 14/05/2019 20:51, Ярослав Лещинский wrote:
>> > Hello Sebastian,
>> > I have added my own BSP for stm32l4 it based on stm32f4. If you want
>> > you can take a look on it -- in attached my patch for a new
>> BSP(stm32l4).
>> Due to the multilib changes, you have to adjust the GCC options for your
>> BSP:
>> -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16 -mfloat-abi=hard
>> See also:
>> https://docs.rtems.org/branches/master/cpu-supplement/arm.html#multilibs
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone : +49 89 189 47 41-16
>> Fax : +49 89 189 47 41-09
>> E-Mail : sebastian.huber at embedded-brains.de
>> PGP : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> Kind regards,
> *Yaroslav Leshchinsky*
Kind regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190515/21315dbc/attachment.html>
