fatal after a new source-builder update
Ярослав Лещинский
midniwalker at gmail.com
Wed May 15 16:30:35 UTC 2019
sorry, my fault -- forgot to rebuild the whole project.
Everything works fine with enabled FPU (-mthumb -mcpu=cortex-m4
-mfpu=fpv4-sp-d16 -mfloat-abi=hard)
On Wed, 15 May 2019 at 17:06, Ярослав Лещинский <midniwalker at gmail.com>
wrote:
> if change to CPU_CFLAGS = -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16
> -mfloat-abi=softfp, application not responded at all.
> On Wed, 15 May 2019 at 16:45, Ярослав Лещинский <midniwalker at gmail.com>
> wrote:
>> yes, I know, I just checked that behavior is the same as before.
>> With these flags -mthumb -mcpu=cortex-m4 -mfpu=fpv4-sp-d16
>> -mfloat-abi=hard
>> I got error from linker:
>> /home/midnight/rtems/toolchain/5/lib/gcc/arm-rtems5/7.4.1/../../../../arm-rtems5/bin/ld:
>> error: o-optimize/test.exe uses VFP register arguments, /
>> home/midnight/workspace/rtems/build/arm-rtems5/stm32l4/lib/librtemsbsp.a(bspfatal-default.o)
>> does not
>> failed to merge target specific data of file /home/midnig
>> Currently I'm trying to figure out what is a problem.
>> On Wed, 15 May 2019 at 16:33, Sebastian Huber <
>> sebastian.huber at embedded-brains.de> wrote:
>>> On 15/05/2019 15:31, Ярослав Лещинский wrote:
>>> > problem solved after edition of CPU_FLAGS as mentioned in stm32f4.cfg:
>>> > CPU_FLAGS = -mthumb -mcpu=cortex-m4
>>> If you use these flags, then you don't use the floating point
>>> instructions.
>>> Sebastian Huber, embedded brains GmbH
>>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>>> Phone : +49 89 189 47 41-16
>>> Fax : +49 89 189 47 41-09
>>> E-Mail : sebastian.huber at embedded-brains.de
>>> PGP : Public key available on request.
>>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> Kind regards,
>> *Yaroslav Leshchinsky*
> Kind regards,
Kind regards,
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190515/bdf9dc3a/attachment.html>
