AW: SMP for pc686 BSP
Fri May 17 02:26:07 UTC 2019
On 17/5/19 2:11 am, Jan.Sommer at dlr.de wrote:
>> -----Ursprüngliche Nachricht-----
>> Von: Joel Sherrill [mailto:joel at rtems.org]
>> Gesendet: Donnerstag, 16. Mai 2019 16:33
>> An: Sommer, Jan
>> Cc: rtems-devel at rtems.org
>> Betreff: Re: SMP for pc686 BSP
>> On Thu, May 16, 2019, 9:01 AM <Jan.Sommer at dlr.de> wrote:
>> 	Hello,
>> 	I have been working recently to enable SMP for the pc686-BSP and
>> managed to get a basic setup running with 2 cores which currently passes
>> 44/57 smptests.
>> 	Next step is to make it work for arbitrary numbers of cores. The goal
>> is to push the patches upstream. That's why I would like to ask the more
>> experienced x86-gurus what would be the preferred direction for some
>> questions.
>> 	1. If I understand it correctly the start16.S is only compiled for SMP
>> configurations since bin2boot has been removed.
>> 	Would you be ok, if I create a "startAP.S" from it, i.e. remove the
>> ifdef SMP_SECONDARY_CORE and the A20 gate enabling (is done by the
>> BSP) to have a minimal ASM-file to bring up an AP?
>> 	2. According to the Intel MultiProcessor Specification the LAPIC IDs
>> do not have to be consecutive
>> 	Thus, in smp-imps.h the "imps_cpu_apic_map" is created. It is
>> populated at the beginning, but all other code uses the LAPIC ID for
>> processor identification.
>> 	Are non-consecutive processor numbers only a theoretical issue, or
>> do they appear in real life as well?
>> 	Should I change the code to use the map or keep using the the LAPIC
>> ID?
>> 	3. In the current setup the AP has its own global descriptor table
>> located in start16.S, but because TLS uses the GS segment and writes to it
>> during context switches, it will create problems with multiple APs.
>> 	One idea would be to create a dedicated GDT for each AP and copy
>> the GDT of the BSP before starting each AP. For that I could
>> 	a) define an array of GDTs, but the problem is the dimension as
>> CONFIGURE_MAXIUM_PROCESSORS is not known when compiling the
>> RTEMS libraries.
>> 	b) add it in the Per_CPU_Control structure to the cpu_per_cpu field.
>> 	c) let the BSP allocate memory for each AP's GDT using malloc
>> 	or d) I could update the existing GDT in ldsegs.S to have additional
>> GS segments for each processor core. Question is again how many sections I
>> should put there (255?) and if that would create problems for the user
>> segments (haven't checked yet where they are used).
>> 	Any other ideas, remarks or hints for possible pitfalls are also
>> greatly appreciated.
>> I am happy with anything you do to clean up this BSP to clean it up in single
>> or multiprocessor mode.
>> One ticket you need to address is that the context switch is missing the
>> interlock logic that avoids issues when a thread is migrated. Without the
>> sync point, you can be restoring a thread on one cpu on on core before it is
>> completely saved. I don't recall the ticket number.
> Is it this ticket?: https://devel.rtems.org/ticket/2183
> I looked at the changes from Sebastian and updated the cpu_asm.S to be more close to the one of the ARM architecture.
> I haven't been able to test that in detail yet, because some troubles in getting the APs to properly boot.
> For me the biggest open question atm is 3.) regarding what to do with the GDTs. At the moment I lean towards option 3b and adding the information to the per_CPU structure, because it seems pretty easy.
> In common setups this would increase the structure by 48 bytes additional space (8 bytes for NULL, text, data, gs and 2 user sections).
> Would that be a problem?
Does cpukit/include/rtems/score/percpudata.h help?
I am not sure how this is put together but the comments at the top of the file
seem to indicate this exists for this type of purpose. It looks pretty neat.
