How can I use the covoar tool?
Fri May 17 11:20:05 UTC 2019
On 17/05/2019 10:49, Vijay Kumar Banerjee wrote:
> covoar -S
> /home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/leon3-sis-symbols.ini
> -O coverage
> -E/home/lunatic/development/rtems/rtems-tools/tester/rtems/testing/coverage/Explanations.txt
> -p RTEMS-5 sparc-rtems5/c/leon3/testsuites/sptests/spversion01.exe -v
> -fTSIM
> Created unified coverage map for rtems_initialize_executive (0x0 - 0x4b)
> Created unified coverage map for rtems_shutdown_executive (0x0 - 0x13)
> Created unified coverage map for rtems_fatal_error_occurred (0x0 - 0x13)
> Created unified coverage map for rtems_get_version_string (0x0 - 0xb)
> Created unified coverage map for _IO_Initialize_all_drivers (0x0 - 0x4b)
> Created unified coverage map for rtems_io_initialize (0x0 - 0x5b)
> Created unified coverage map for rtems_version (0x0 - 0xb)
> Created unified coverage map for rtems_version_major (0x0 - 0x7)
> Created unified coverage map for rtems_version_minor (0x0 - 0x7)
> error: ExecutableInfo::findCoverageMap: rtems_version_revision
> So there's something in rtems_version_revision() in spversion01/
> that's making it unhappy.
Is there some high level description available what the covoar tool
does? For example its inputs and outputs and the course data flow of the
program?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
