[PATCH] posix: Remove unused OBJECTS_POSIX_INTERRUPTS
Joel Sherrill
joel at rtems.org
Fri May 17 19:38:31 UTC 2019
Hi
I have no idea where POSIX Interrupts came from. That doesn't match
anything in the POSIX standard or any draft I have seen.
I assume you intentionally left the gap in numbering of POSIX API classes
for historical consistency. But it does leave a gap in the
_Objects_Information_Table and wastes a tiny bit of RAM.
--joel
On Fri, May 17, 2019 at 2:21 AM Sebastian Huber <
> cpukit/include/rtems/score/objectdata.h | 1 -
> cpukit/rtems/src/rtemsobjectgetapiclassname.c | 3 ---
> 2 files changed, 4 deletions(-)
> diff --git a/cpukit/include/rtems/score/objectdata.h
> b/cpukit/include/rtems/score/objectdata.h
> index f6ece16c0e..ce6e3c63a4 100644
> --- a/cpukit/include/rtems/score/objectdata.h
> +++ b/cpukit/include/rtems/score/objectdata.h
> @@ -80,7 +80,6 @@ typedef enum {
> OBJECTS_POSIX_NO_CLASS = 0,
> OBJECTS_POSIX_THREADS = 1,
> OBJECTS_POSIX_KEYS = 2,
> - OBJECTS_POSIX_INTERRUPTS = 3,
> OBJECTS_POSIX_MESSAGE_QUEUES = 5,
> OBJECTS_POSIX_SEMAPHORES = 7,
> OBJECTS_POSIX_TIMERS = 9,
> diff --git a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
> b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
> index a00b06b990..1f2952765d 100644
> --- a/cpukit/rtems/src/rtemsobjectgetapiclassname.c
> +++ b/cpukit/rtems/src/rtemsobjectgetapiclassname.c
> @@ -45,9 +45,6 @@ static const rtems_assoc_t
> rtems_object_api_classic_assoc[] = {
> static const rtems_assoc_t rtems_object_api_posix_assoc[] = {
> { "Thread", OBJECTS_POSIX_THREADS, 0},
> { "Key", OBJECTS_POSIX_KEYS, 0},
> -#ifdef RTEMS_POSIX_API
> - { "Interrupt", OBJECTS_POSIX_INTERRUPTS, 0},
> -#endif
> { "Message Queue", OBJECTS_POSIX_MESSAGE_QUEUES, 0},
> { "Semaphore", OBJECTS_POSIX_SEMAPHORES, 0},
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190517/a18867d5/attachment.html>
