[PATCH 08/18] score: Move per-processor job data structures
Mon May 20 07:33:34 UTC 2019
This enables re-use for other purposes, e.g. replacement for
SMP_MESSAGE_TEST.
 cpukit/include/rtems/score/percpu.h   | 59 ++++++++++++++++++++++--
 cpukit/score/src/smpmulticastaction.c | 87 ++++++++---------------------------
 2 files changed, 74 insertions(+), 72 deletions(-)
diff --git a/cpukit/include/rtems/score/percpu.h b/cpukit/include/rtems/score/percpu.h
index e97f6cdfbd..eff71c4ec1 100644
--- a/cpukit/include/rtems/score/percpu.h
+++ b/cpukit/include/rtems/score/percpu.h
@@ -77,8 +77,6 @@ struct _Thread_Control;
 struct Scheduler_Context;
-struct Per_CPU_Job;
  *  @defgroup PerCPU RTEMS Per CPU Information
@@ -175,6 +173,61 @@ typedef enum {
   PER_CPU_STATE_SHUTDOWN
 } Per_CPU_State;
+typedef void ( *Per_CPU_Job_handler )( void *arg );
+ * @brief Context for per-processor jobs.
+ * This is separate from Per_CPU_Job to save stack memory in
+ * _SMP_Multicast_action().
+typedef struct {
+   * @brief The job handler.
+  Per_CPU_Job_handler handler;
+   * @brief The job handler argument.
+  void *arg;
+} Per_CPU_Job_context;
+ * Value for the Per_CPU_Job::done member to indicate that a job is done
+ * (handler was called on the target processor).  Must not be a valid pointer
+ * value since it overlaps with the Per_CPU_Job::next member.
+#define PER_CPU_JOB_DONE 1
+ * @brief A per-processor job.
+ * This structure must be as small as possible due to stack space constraints
+ * in _SMP_Multicast_action().
+typedef struct Per_CPU_Job {
+  union {
+     * @brief The next job in the corresponding per-processor job list.
+    struct Per_CPU_Job *next;
+     * @brief Indication if the job is done.
+     * A job is done if this member has the value PER_CPU_JOB_DONE.  This
+     * assumes that PER_CPU_JOB_DONE is not a valid pointer value.
+    Atomic_Ulong done;
+   * @brief Pointer to the job context to get the handler and argument.
+  const Per_CPU_Job_context *context;
+} Per_CPU_Job;
 #endif /* defined( RTEMS_SMP ) */
@@ -316,7 +369,7 @@ typedef struct Per_CPU_Control {
   uint32_t isr_nest_level;
-   * @brief Indicetes if an ISR thread dispatch is disabled.
+   * @brief Indicates if an ISR thread dispatch is disabled.
    * This flag is context switched with each thread.  It indicates that this
    * thread has an interrupt stack frame on its stack.  By using this flag, we
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index a525289842..ad3b1531ec 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -32,62 +32,6 @@
 #include <rtems/score/smpimpl.h>
-typedef struct Per_CPU_Job Per_CPU_Job;
-typedef struct Per_CPU_Jobs Per_CPU_Jobs;
- * Value for the Per_CPU_Job::done member to indicate that a job is done
- * (handler was called on the target processor).  Must not be a valid pointer
- * value since it overlaps with the Per_CPU_Job::next member.
-#define PER_CPU_JOB_DONE 1
- * @brief A per-processor job.
-struct Per_CPU_Job {
-  union {
-     * @brief The next job in the corresponding per-processor job list.
-    Per_CPU_Job *next;
-     * @brief Indication if the job is done.
-     * A job is done if this member has the value PER_CPU_JOB_DONE.  This
-     * assumes that PER_CPU_JOB_DONE is not a valid pointer value.
-    Atomic_Ulong done;
-   * @brief Back pointer to the jobs to get the handler and argument.
-  Per_CPU_Jobs *jobs;
- * @brief A collection of jobs, one for each processor.
-struct Per_CPU_Jobs {
-   * @brief The job handler.
-  SMP_Action_handler handler;
-   * @brief The job handler argument.
-  void *arg;
-   * @brief One job for each potential processor.
-  Per_CPU_Job Jobs[ CPU_MAXIMUM_PROCESSORS ];
 #define _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, lock_context ) \
   _ISR_lock_ISR_disable_and_acquire( &( cpu )->Jobs.Lock, lock_context )
@@ -102,13 +46,13 @@ void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
   _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
   while ( ( job = cpu->Jobs.head ) != NULL ) {
     cpu->Jobs.head = job->next;
     _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
-    jobs = job->jobs;
-    ( *jobs->handler )( jobs->arg );
+    context = job->context;
+    ( *context->handler )( context->arg );
     _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
@@ -138,9 +82,14 @@ static void _Per_CPU_Try_perform_jobs( Per_CPU_Control *cpu_self )
+typedef struct {
+  Per_CPU_Job_context Context;
+  Per_CPU_Job         Jobs[ CPU_MAXIMUM_PROCESSORS ];
+} SMP_Multicast_jobs;
 static void _SMP_Issue_action_jobs(
   const Processor_mask *targets,
-  Per_CPU_Jobs         *jobs,
+  SMP_Multicast_jobs   *jobs,
   uint32_t              cpu_max
@@ -155,7 +104,7 @@ static void _SMP_Issue_action_jobs(
       job = &jobs->Jobs[ cpu_index ];
       _Atomic_Store_ulong( &job->done, 0, ATOMIC_ORDER_RELAXED );
       _Assert( job->next == NULL );
-      job->jobs = jobs;
+      job->context = &jobs->Context;
       cpu = _Per_CPU_Get_by_index( cpu_index );
@@ -175,9 +124,9 @@ static void _SMP_Issue_action_jobs(
 static void _SMP_Wait_for_action_jobs(
-  const Processor_mask *targets,
-  const Per_CPU_Jobs   *jobs,
-  uint32_t              cpu_max
+  const Processor_mask     *targets,
+  const SMP_Multicast_jobs *jobs,
+  uint32_t                  cpu_max
   uint32_t cpu_index;
@@ -223,14 +172,14 @@ void _SMP_Multicast_action(
   void                 *arg
-  Per_CPU_Jobs jobs;
-  uint32_t     cpu_max;
+  SMP_Multicast_jobs jobs;
+  uint32_t           cpu_max;
   cpu_max = _SMP_Get_processor_maximum();
-  _Assert( cpu_max <= CPU_MAXIMUM_PROCESSORS );
+  _Assert( cpu_max <= RTEMS_ARRAY_SIZE( jobs.Jobs ) );
-  jobs.handler = handler;
-  jobs.arg = arg;
+  jobs.Context.handler = handler;
+  jobs.Context.arg = arg;
   _SMP_Issue_action_jobs( targets, &jobs, cpu_max );
   _SMP_Wait_for_action_jobs( targets, &jobs, cpu_max );
2.16.4
