[PATCH 03/18] smptests: Move SMP broadcast action test case
Mon May 20 07:33:29 UTC 2019
 testsuites/smptests/smpcache01/init.c     | 41 +-------------
 testsuites/smptests/smpmulticast01/init.c | 89 +++++++++++++++++++++++++++----
 2 files changed, 79 insertions(+), 51 deletions(-)
diff --git a/testsuites/smptests/smpcache01/init.c b/testsuites/smptests/smpcache01/init.c
index 878a015bf1..3552a3b6d0 100644
--- a/testsuites/smptests/smpcache01/init.c
+++ b/testsuites/smptests/smpcache01/init.c
@@ -29,7 +29,6 @@ const char rtems_test_name[] = "SMPCACHE 1";
 typedef struct {
   SMP_barrier_Control barrier;
-  uint32_t count[CPU_COUNT];
   bool do_longjmp[CPU_COUNT];
   jmp_buf instruction_invalidate_return_context[CPU_COUNT];
 } test_context;
@@ -43,13 +42,6 @@ static void function_to_flush( void )
   /* Does nothing. Used to give a pointer to instruction address space. */
-static void test_action( void *arg )
-  rtems_test_assert(arg == &ctx);
-  ctx.count[rtems_scheduler_get_processor()]++;
 typedef void ( *test_case )( void );
 static void test_cache_invalidate_entire_instruction( void )
@@ -80,51 +72,26 @@ static void barrier( SMP_barrier_State *bs )
-static void broadcast_test_init( void )
-  ctx.count[rtems_scheduler_get_processor()] = 0;
-static void broadcast_test_body( void )
-  _SMP_Multicast_action( NULL, test_action, &ctx );
-static void broadcast_test_fini( void )
-      == rtems_scheduler_get_processor_maximum()
 static test_case test_cases[] = {
   test_cache_invalidate_entire_instruction,
-  test_cache_invalidate_multiple_instruction_lines,
-  broadcast_test_body
+  test_cache_invalidate_multiple_instruction_lines
 static void call_tests( SMP_barrier_State *bs )
   size_t i;
-  broadcast_test_init();
   for (i = 0; i < RTEMS_ARRAY_SIZE( test_cases ); ++i) {
     barrier( bs );
     ( *test_cases[ i ] )();
     barrier( bs );
-  broadcast_test_fini();
 static void call_tests_isr_disabled( SMP_barrier_State *bs )
   size_t i;
     ISR_Level isr_level;
@@ -134,16 +101,12 @@ static void call_tests_isr_disabled( SMP_barrier_State *bs )
     _ISR_Local_enable( isr_level );
     barrier( bs );
 static void call_tests_with_thread_dispatch_disabled( SMP_barrier_State *bs )
   size_t i;
     Per_CPU_Control *cpu_self;
@@ -153,8 +116,6 @@ static void call_tests_with_thread_dispatch_disabled( SMP_barrier_State *bs )
     barrier( bs );
     _Thread_Dispatch_enable( cpu_self );
 static void cmlog(  const char* str )
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index a2180bdf14..a5ed85c3ef 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -48,11 +48,17 @@ static const T_config config = {
 typedef struct {
-  Atomic_Uint id[CPU_COUNT];
+  rtems_test_parallel_context base;
+  Atomic_Uint id[CPU_COUNT][CPU_COUNT];
 } test_context;
 static test_context test_instance;
+static void clear_ids_by_worker(test_context *ctx, size_t worker_index)
+  memset(&ctx->id[worker_index][0], 0, sizeof(ctx->id[worker_index]));
 static void multicast_action_irq_disabled(
   const Processor_mask *targets,
   SMP_Action_handler handler,
@@ -81,16 +87,16 @@ static void multicast_action_dispatch_disabled(
 static void action(void *arg)
-  test_context *ctx;
+  Atomic_Uint *id;
   uint32_t self;
   unsigned expected;
   bool success;
-  ctx = arg;
+  id = arg;
   self = rtems_scheduler_get_processor();
   expected = 0;
   success = _Atomic_Compare_exchange_uint(
-    &ctx->id[self],
+    &id[self],
     &expected,
     self + 1,
     ATOMIC_ORDER_RELAXED,
@@ -116,17 +122,17 @@ static void test_unicast(
     Processor_mask cpus;
     uint32_t j;
-    memset(ctx, 0, sizeof(*ctx));
+    clear_ids_by_worker(ctx, 0);
     _Processor_mask_Zero(&cpus);
     _Processor_mask_Set(&cpus, i);
-    (*multicast_action)(&cpus, action, ctx);
+    (*multicast_action)(&cpus, action, &ctx->id[0][0]);
     for (j = 0; j < n; ++j) {
       unsigned id;
       ++step;
-      id = _Atomic_Load_uint(&ctx->id[j], ATOMIC_ORDER_RELAXED);
+      id = _Atomic_Load_uint(&ctx->id[0][j], ATOMIC_ORDER_RELAXED);
       if (j == i) {
         T_quiet_eq_uint(j + 1, id);
@@ -155,15 +161,15 @@ static void test_broadcast(
   for (i = 0; i < n; ++i) {
     uint32_t j;
-    (*multicast_action)(NULL, action, ctx);
+    (*multicast_action)(NULL, action, &ctx->id[0][0]);
       unsigned id;
       ++step;
@@ -171,6 +177,65 @@ static void test_broadcast(
   T_step_eq_u32(0, step, n * n);
+static rtems_interval test_duration(void)
+  return rtems_clock_get_ticks_per_second();
+static rtems_interval test_broadcast_init(
+  rtems_test_parallel_context *base,
+  void *arg,
+  size_t active_workers
+  return test_duration();
+static void test_broadcast_body(
+  void *arg,
+  size_t active_workers,
+  size_t worker_index
+  test_context *ctx;
+  ctx = (test_context *) base;
+  while (!rtems_test_parallel_stop_job(&ctx->base)) {
+    clear_ids_by_worker(ctx, worker_index);
+    _SMP_Multicast_action(NULL, action, &ctx->id[worker_index][0]);
+static void test_broadcast_fini(
+  void *arg,
+  /* Do nothing */
+static const rtems_test_parallel_job test_jobs[] = {
+    .init = test_broadcast_init,
+    .body = test_broadcast_body,
+    .fini = test_broadcast_fini,
+    .cascade = true
+T_TEST_CASE(ParallelBroadcast)
+  rtems_test_parallel(
+    &test_instance.base,
+    NULL,
+    &test_jobs[0],
+    RTEMS_ARRAY_SIZE(test_jobs)
 static void test_before_multitasking(void)
   test_context *ctx;
@@ -326,7 +391,9 @@ static void fatal_extension(
 #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_TASKS CPU_COUNT
+#define CONFIGURE_MAXIMUM_TIMERS 1
 #define CONFIGURE_MAXIMUM_PROCESSORS CPU_COUNT
2.16.4
