[PATCH 10/18] score: Modify _Per_CPU_Perform_jobs()
Mon May 20 07:33:36 UTC 2019
Process only the jobs initially registered on the processing list.  This
makes it possible to add jobs for the current processor in a job
handler.  These jobs are processed with the next
SMP_MESSAGE_PERFORM_JOBS message.  The lock is only acquired and
released once.
 cpukit/score/src/smpmulticastaction.c     | 12 +++++----
 testsuites/smptests/smpmulticast01/init.c | 41 +++++++++++++++++++++++++++++++
 2 files changed, 48 insertions(+), 5 deletions(-)
diff --git a/cpukit/score/src/smpmulticastaction.c b/cpukit/score/src/smpmulticastaction.c
index 1207000e6a..b5d21a4b56 100644
--- a/cpukit/score/src/smpmulticastaction.c
+++ b/cpukit/score/src/smpmulticastaction.c
@@ -44,18 +44,20 @@ void _Per_CPU_Perform_jobs( Per_CPU_Control *cpu )
   Per_CPU_Job      *job;
   _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
+  job = cpu->Jobs.head;
+  cpu->Jobs.head = NULL;
+  _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
-  while ( ( job = cpu->Jobs.head ) != NULL ) {
+  while ( job != NULL ) {
     const Per_CPU_Job_context *context;
-    cpu->Jobs.head = job->next;
-    _Per_CPU_Jobs_release_and_ISR_enable( cpu, &lock_context );
+    Per_CPU_Job               *next;
     context = job->context;
+    next = job->next;
     ( *context->handler )( context->arg );
     _Atomic_Store_ulong( &job->done, PER_CPU_JOB_DONE, ATOMIC_ORDER_RELEASE );
-    _Per_CPU_Jobs_ISR_disable_and_acquire( cpu, &lock_context );
+    job = next;
diff --git a/testsuites/smptests/smpmulticast01/init.c b/testsuites/smptests/smpmulticast01/init.c
index 9e5d15f795..e7c533027f 100644
--- a/testsuites/smptests/smpmulticast01/init.c
+++ b/testsuites/smptests/smpmulticast01/init.c
@@ -394,6 +394,47 @@ T_TEST_CASE(JobOrder)
   _Thread_Dispatch_enable(cpu_self);
+#define TEST_ADD_JOB_IN_JOB_JOBS 3
+static Per_CPU_Job add_job_in_job_jobs[TEST_ADD_JOB_IN_JOB_JOBS];
+static void add_job_in_job_handler_0(void *arg)
+  T_step(1, "invalid job order");
+  _Per_CPU_Add_job(_Per_CPU_Get(), &add_job_in_job_jobs[1]);
+static void add_job_in_job_handler_1(void *arg)
+  T_step(3, "invalid job order");
+static const Per_CPU_Job_context
+add_job_in_job_contexts[TEST_ADD_JOB_IN_JOB_JOBS] = {
+  { .handler = add_job_in_job_handler_0 },
+  { .handler = add_job_in_job_handler_1 }
+T_TEST_CASE(AddJobInJob)
+  Per_CPU_Control *cpu_self;
+  size_t i;
+  T_plan(4);
+  cpu_self = _Thread_Dispatch_disable();
+  for (i = 0; i < TEST_ADD_JOB_IN_JOB_JOBS; ++i) {
+    add_job_in_job_jobs[i].context = &add_job_in_job_contexts[i];
+  _Per_CPU_Add_job(cpu_self, &add_job_in_job_jobs[0]);
+  T_step(0, "wrong job processing time");
+  _SMP_Send_message(_Per_CPU_Get_index(cpu_self), SMP_MESSAGE_PERFORM_JOBS);
+  T_step(2, "wrong job processing time");
+  _Thread_Dispatch_enable(cpu_self);
 T_TEST_CASE(UnicastDuringMultitaskingIRQDisabled)
   test_unicast(&test_instance, multicast_action_irq_disabled);
2.16.4
