[PATCH 14/18] score: Remove unused SMP_MESSAGE_TEST
Mon May 20 07:33:40 UTC 2019
All uses were replaced by per-processor jobs.
 cpukit/include/rtems/score/smpimpl.h | 32 +-------------------------------
 cpukit/score/src/smp.c               |  2 --
 2 files changed, 1 insertion(+), 33 deletions(-)
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index 1b7841630b..c0fe7a03e2 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -43,19 +43,12 @@ extern "C" {
 #define SMP_MESSAGE_SHUTDOWN 0x1UL
- * @brief SMP message to request a test handler invocation.
- * @see _SMP_Send_message().
-#define SMP_MESSAGE_TEST 0x2UL
  * @brief SMP message to perform per-processor jobs.
-#define SMP_MESSAGE_PERFORM_JOBS 0x4UL
+#define SMP_MESSAGE_PERFORM_JOBS 0x2UL
  * @brief SMP fatal codes.
@@ -136,25 +129,6 @@ void _SMP_Start_multitasking_on_secondary_processor(
   Per_CPU_Control *cpu_self
 ) RTEMS_NO_RETURN;
-typedef void ( *SMP_Test_message_handler )( Per_CPU_Control *cpu_self );
-extern SMP_Test_message_handler _SMP_Test_message_handler;
- * @brief Sets the handler for test messages.
- * This handler can be used to test the inter-processor interrupt
- * implementation.
- * @param handler The handler for text messages.
-static inline void _SMP_Set_test_message_handler(
-  SMP_Test_message_handler handler
-  _SMP_Test_message_handler = handler;
  * @brief Interrupts handler for inter-processor interrupts.
@@ -186,10 +160,6 @@ static inline long unsigned _SMP_Inter_processor_interrupt_handler(
       /* does not continue past here */
-    if ( ( message & SMP_MESSAGE_TEST ) != 0 ) {
-      ( *_SMP_Test_message_handler )( cpu_self );
     if ( ( message & SMP_MESSAGE_PERFORM_JOBS ) != 0 ) {
       _Per_CPU_Perform_jobs( cpu_self );
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 17d6c8bc67..306d1ea4b4 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -252,5 +252,3 @@ void _SMP_Send_message_multicast(
-SMP_Test_message_handler _SMP_Test_message_handler;
2.16.4
