[PATCH v2] rtemstoolkit/path : Add listdir function
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon May 20 11:23:51 UTC 2019
rtemstoolkit/path.py | 29 ++++++++++++++++++++++++++++-
tester/rt/coverage.py | 4 ++--
2 files changed, 30 insertions(+), 3 deletions(-)
diff --git a/rtemstoolkit/path.py b/rtemstoolkit/path.py
index 2b569ae..0044c7b 100644
--- a/rtemstoolkit/path.py
+++ b/rtemstoolkit/path.py
@@ -157,6 +157,33 @@ def expanduser(path):
path = os.path.expanduser(path)
return shell(path)
+def listdir(path):
+ path = host(path)
+ files = []
+ if not exists(path):
+ raise error.general('path does not exist : %s' % (path))
+ elif not isdir(path):
+ raise error.general('path is not a directory: %s' % (path))
+ else:
+ if windows:
+ try:
+ files = os.listdir(host(path))
+ except IOError:
+ raise error.general('Could not list files for path: %s' % (path))
+ except OSError as e:
+ raise error.general('Could not list files for path: %s: %s' % (path, str(e)))
+ except WindowsError as e:
+ else:
+ try:
+ except IOError:
+ return files
def collect_files(path_):
# Convert to shell paths and return shell paths.
@@ -184,7 +211,7 @@ def copy_tree(src, dst):
hdst = host(dst)
if os.path.exists(src) and os.path.isdir(src):
- names = os.listdir(src)
+ names = listdir(src)
else:
names = [basename(src)]
src = dirname(src)
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
index bdf3c5f..31e2cd7 100644
--- a/tester/rt/coverage.py
+++ b/tester/rt/coverage.py
@@ -215,7 +215,7 @@ class report_gen_html:
for symbol_set in self.symbol_sets:
symbol_set_dir = path.join(self.build_dir,
self.bsp + '-coverage', symbol_set)
- html_files = os.listdir(symbol_set_dir)
+ html_files = path.listdir(symbol_set_dir)
for html_file in html_files:
html_file = path.join(symbol_set_dir, html_file)
if path.exists(html_file) and 'html' in html_file:
@@ -291,7 +291,7 @@ class symbol_parser(object):
config.add_section('symbol-sets')
config.set('symbol-sets', 'sets', sset)
config.add_section(sset)
- object_files = [o for o in os.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
+ object_files = [o for o in path.listdir(self.symbol_sets[sset]) if o[-1] == 'o']
object_paths = []
for o in object_files:
object_paths.append(path.join(self.symbol_sets[sset], o))
2.20.1
