Potential SIS or RTEMS/libbsd problem
Jiri Gaisler jiri at gaisler.se
Wed May 22 07:39:54 UTC 2019
On 5/22/19 8:03 AM, Sebastian Huber wrote:
> Hello,
> in the libbsd there is a test for the Epoch Based Reclamation:
> https://git.rtems.org/rtems-libbsd/tree/testsuite/epoch01/test_main.c
> When I run this test using the leon3 BSP on real hardware (150MHz NGMP FP) the test completes successfully.
> If I run the test on the SIS, it is stuck at some point (using "-m 1" works):
> sparc-rtems5-sis -leon3 -nouartrx -r -tlim 200 s -m 2 build/sparc-rtems5-leon3-everything/epoch01.exe
This test needs a shorter time-slice in the simulator to succeed (-d option). The more cpus, the lower number of clocks in the slice is needed. Through trial-and-error, these values seem to work:
2 CPUs: -m 2 -d 25
3 CPUs: -m 3 -d 10
4 CPUs will not work, even if -d 1 is set. This is most likely a simulator problem, I will try to find time to look at it in more detail. A quick trace shows that all CPUs are stuck in a loop checking for a lock or similar:
$ ./sis -leon3 ~/epoch01.exe -m 4 -d 1
 SIS - SPARC/RISCV instruction simulator 2.14,  copyright Jiri Gaisler 2019
 Bug-reports to jiri at gaisler.se
 LEON3 emulation enabled, 4 cpus online, delta 1 clocks
 Loaded /home/jiri/epoch01.exe, entry 0x40000000
cpu0> run
Waking CPU 1
Waking CPU 2
Waking CPU 3
*** LIBBSD EPOCH 1 TEST ***
nexus0: <RTEMS Nexus device>
<TestEpoch01>
  <EnterExit activeWorker="1">
    <Counter worker="0">74357</Counter>
  </EnterExit>
  <EnterExit activeWorker="2">
    <Counter worker="0">74464</Counter>
    <Counter worker="1">59621</Counter>
  </EnterExit>
  <EnterExit activeWorker="3">
    <Counter worker="0">74353</Counter>
    <Counter worker="1">59529</Counter>
    <Counter worker="2">74710</Counter>
  </EnterExit>
  <EnterExit activeWorker="4">
    <Counter worker="0">74221</Counter>
    <Counter worker="1">66362</Counter>
    <Counter worker="2">74605</Counter>
    <Counter worker="3">74605</Counter>
  </EnterExit>
  <EnterListOpExit activeWorker="1">
    <Counter worker="0">53231</Counter>
    <Removals worker="0">82</Removals>
  </EnterListOpExit>
  <EnterListOpExit activeWorker="2">
    <Counter worker="0">51659</Counter>
    <Counter worker="1">51862</Counter>
    <Removals worker="0">42</Removals>
    <Removals worker="1">42</Removals>
  </EnterListOpExit>
  <EnterListOpExit activeWorker="3">
    <Counter worker="0">50492</Counter>
    <Counter worker="1">46310</Counter>
    <Counter worker="2">51516</Counter>
    <Removals worker="0">25</Removals>
    <Removals worker="1">24</Removals>
    <Removals worker="2">24</Removals>
  </EnterListOpExit>
  <EnterListOpExit activeWorker="4">
    <Counter worker="0">46105</Counter>
    <Counter worker="1">41697</Counter>
    <Counter worker="2">46499</Counter>
    <Counter worker="3">46515</Counter>
    <Removals worker="0">19</Removals>
    <Removals worker="1">18</Removals>
    <Removals worker="2">18</Removals>
    <Removals worker="3">18</Removals>
  </EnterListOpExit>
  <EnterExitPreempt activeWorker="1">
    <Counter worker="0">29273</Counter>
  </EnterExitPreempt>
  <EnterExitPreempt activeWorker="2">
    <Counter worker="0">29262</Counter>
    <Counter worker="1">37024</Counter>
  </EnterExitPreempt>
  <EnterExitPreempt activeWorker="3">
    <Counter worker="0">32622</Counter>
    <Counter worker="1">36973</Counter>
    <Counter worker="2">36973</Counter>
  </EnterExitPreempt>
  <EnterExitPreempt activeWorker="4">
    <Counter worker="0">29126</Counter>
    <Counter worker="1">36917</Counter>
    <Counter worker="2">36917</Counter>
    <Counter worker="3">36918</Counter>
  </EnterExitPreempt>
  <EnterListOpExitPreempt activeWorker="1">
    <Counter worker="0">27539</Counter>
    <Removals worker="0">61</Removals>
  </EnterListOpExitPreempt>
Interrupt!
 Stopped at time 1090141103 (21802.822 ms)
cpu0> tra 20
cpu 1  1090141103  40001840:  81e80000   restore
cpu 2  1090141103  401cc2f4:  82102000   mov  0, %g1
cpu 3  1090141103  401cc2f4:  82102000   mov  0, %g1
cpu 0  1090141104  40001798:  7fffffea   call  0x40001740
cpu 1  1090141104  40001844:  81c3e008   retl
cpu 2  1090141104  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 3  1090141104  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 0  1090141105  4000179c:  01000000   nop
cpu 0  1090141106  40001740:  9de3bfa0   save  %sp, -96, %sp
cpu 1  1090141106  40001848:  01000000   nop
cpu 2  1090141106  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 3  1090141106  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 0  1090141107  40001744:  01000000   nop
cpu 1  1090141107  400018a0:  01000000   nop
cpu 0  1090141108  40001748:  81e80000   restore
cpu 1  1090141108  400018a4:  81e80000   restore
cpu 2  1090141108  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 3  1090141108  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 0  1090141109  4000174c:  81c3e008   retl
cpu 1  1090141109  400018a8:  81c3e008   retl
cpu 2  1090141109  401cc2f4:  82102000   mov  0, %g1
cpu 3  1090141109  401cc2f4:  82102000   mov  0, %g1
cpu 2  1090141110  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 3  1090141110  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 0  1090141111  40001750:  01000000   nop
cpu 1  1090141111  400018ac:  01000000   nop
cpu 0  1090141112  400017a0:  c207a044   ld  [%fp + 0x44], %g1
cpu 1  1090141112  40002484:  c207bff0   ld  [%fp - 0x10], %g1
cpu 2  1090141112  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 3  1090141112  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 0  1090141114  400017a4:  c407a048   ld  [%fp + 0x48], %g2
cpu 1  1090141114  40002488:  90100001   mov  %g1, %o0
cpu 2  1090141114  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 3  1090141114  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 2  1090141115  401cc2f4:  82102000   mov  0, %g1
cpu 3  1090141115  401cc2f4:  82102000   mov  0, %g1
cpu 0  1090141116  400017a8:  c4204000   st  %g2, [%g1]
cpu 1  1090141116  4000248c:  7ffffcb2   call  0x40001754
cpu 2  1090141116  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 3  1090141116  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 1  1090141117  40002490:  01000000   nop
cpu 1  1090141118  40001754:  9de3bf98   save  %sp, -104, %sp
cpu 2  1090141118  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 3  1090141118  401cc2ec:  80a08001   cmp  %g2, %g1
cpu 0  1090141119  400017ac:  7fffffe5   call  0x40001740
cpu 1  1090141119  40001758:  f027a044   st  %i0, [%fp + 0x44]
cpu 0  1090141120  400017b0:  01000000   nop
cpu 2  1090141120  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 3  1090141120  401cc2f0:  12bffffe   bne  0x401cc2e8
cpu 0  1090141121  40001740:  9de3bfa0   save  %sp, -96, %sp
cpu 2  1090141121  401cc2f4:  82102000   mov  0, %g1
cpu 3  1090141121  401cc2f4:  82102000   mov  0, %g1
cpu 0  1090141122  40001744:  01000000   nop
cpu 1  1090141122  4000175c:  7ffffff9   call  0x40001740
cpu 2  1090141122  401cc2e8:  c200c000   ld  [%g3], %g1
cpu 3  1090141122  401cc2e8:  c200c000   ld  [%g3], %g1
 Stopped at time 1090141123 (21802.822 ms)
cpu0>
