taking the Interrupt Manager Extension as an example for the qualification process
Ting Peng ting.peng at embedded-brains.de
Wed May 22 08:37:09 UTC 2019
Hello,
As we need to choose one RTEMS software component as an example to have
an overview of the qualification process, Sebastian Huber suggests to
take the Interrupt Manager Extension
(https://docs.rtems.org/doxygen/branches/master/group__rtems__interrupt__extension.html)
as the example. The goal is to integrate the Interrupt Manager Extension
in the Interrupt Manager. The example will cover the topics of
requirements, test plans, test code, test reports, code coverage, other
metrics, software architecture, software detailed design, traceability
items (open issue) and Interface control document (ICD) vs. RTEMS
Classic API Guide (open issue).
Thank you for reading this email.
Best regards,
Ting Peng
