[PATCH] score: Compact objects class indices
Joel Sherrill
joel at rtems.org
Wed May 22 13:23:23 UTC 2019
I'm OK with this.
Is the statement that the API and class numbers are not
guaranteed to be held constant across releases something
that should be explicitly in a comment or requirement?
On Wed, May 22, 2019 at 12:52 AM Sebastian Huber <
> cpukit/include/rtems/score/objectdata.h | 48
> 1 file changed, 28 insertions(+), 20 deletions(-)
> diff --git a/cpukit/include/rtems/score/objectdata.h
> b/cpukit/include/rtems/score/objectdata.h
> index ce6e3c63a4..a33f9d497f 100644
> --- a/cpukit/include/rtems/score/objectdata.h
> +++ b/cpukit/include/rtems/score/objectdata.h
> @@ -50,8 +50,10 @@ typedef struct {
> * for RTEMS internal object classes.
> typedef enum {
> - OBJECTS_INTERNAL_NO_CLASS = 0,
> - OBJECTS_INTERNAL_THREADS = 1
> + OBJECTS_INTERNAL_NO_CLASS = 0,
> + /* Must be one, see __Thread_Get_objects_information() */
> + OBJECTS_INTERNAL_THREADS = 1
> } Objects_Internal_API;
> @@ -59,17 +61,20 @@ typedef enum {
> * for the RTEMS Classic API.
> typedef enum {
> - OBJECTS_CLASSIC_NO_CLASS = 0,
> - OBJECTS_RTEMS_TASKS = 1,
> - OBJECTS_RTEMS_TIMERS = 2,
> - OBJECTS_RTEMS_SEMAPHORES = 3,
> - OBJECTS_RTEMS_MESSAGE_QUEUES = 4,
> - OBJECTS_RTEMS_PARTITIONS = 5,
> - OBJECTS_RTEMS_REGIONS = 6,
> - OBJECTS_RTEMS_PORTS = 7,
> - OBJECTS_RTEMS_PERIODS = 8,
> - OBJECTS_RTEMS_EXTENSIONS = 9,
> - OBJECTS_RTEMS_BARRIERS = 10
> + OBJECTS_CLASSIC_NO_CLASS = 0,
> + OBJECTS_RTEMS_TASKS = 1,
> + OBJECTS_RTEMS_TIMERS,
> + OBJECTS_RTEMS_SEMAPHORES,
> + OBJECTS_RTEMS_MESSAGE_QUEUES,
> + OBJECTS_RTEMS_PARTITIONS,
> + OBJECTS_RTEMS_REGIONS,
> + OBJECTS_RTEMS_PORTS,
> + OBJECTS_RTEMS_PERIODS,
> + OBJECTS_RTEMS_EXTENSIONS,
> + OBJECTS_RTEMS_BARRIERS
> } Objects_Classic_API;
> @@ -77,13 +82,16 @@ typedef enum {
> * for the POSIX API.
> typedef enum {
> - OBJECTS_POSIX_NO_CLASS = 0,
> - OBJECTS_POSIX_THREADS = 1,
> - OBJECTS_POSIX_KEYS = 2,
> - OBJECTS_POSIX_MESSAGE_QUEUES = 5,
> - OBJECTS_POSIX_SEMAPHORES = 7,
> - OBJECTS_POSIX_TIMERS = 9,
> - OBJECTS_POSIX_SHMS = 12
> + OBJECTS_POSIX_NO_CLASS = 0,
> + OBJECTS_POSIX_THREADS = 1,
> + OBJECTS_POSIX_KEYS,
> + OBJECTS_POSIX_MESSAGE_QUEUES,
> + OBJECTS_POSIX_SEMAPHORES,
> + OBJECTS_POSIX_TIMERS,
> + OBJECTS_POSIX_SHMS
> } Objects_POSIX_API;
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190522/fab41ab4/attachment.html>
