[PATCH] score: Compact objects class indices
Thu May 23 05:13:25 UTC 2019
On 22/05/2019 15:55, Joel Sherrill wrote:
> On Wed, May 22, 2019 at 8:40 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 22/05/2019 15:23, Joel Sherrill wrote:
>     > I'm OK with this.
>     > Is the statement that the API and class numbers are not
>     > guaranteed to be held constant across releases something
>     > that should be explicitly in a comment or requirement?
>     The question is how can an application get one of the class
>     numbers? I
>     think the only legal way is to create an object and then use
>     rtems_object_id_get_class(). The constants are only for internal
>     use and
>     not a part of the API?
> Originally, they were not exposed at all and the encoding of the object
> id was just an artifact of the implementation. The rtems_object* methods
> were added to make it easier to decode an existing Id.
> So yes. These constants have never been part of the public API because
> applications were being supported in decoding Ids, not creating them.
> Have you got a use case in mind to add them?
No, I think it is good that they are somewhat hidden.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
