Where to Store Requirements for RTEMS Components
Thu May 23 07:13:54 UTC 2019
On 23/05/2019 08:44, Chris Johns wrote:
> On 23/5/19 3:40 pm, Sebastian Huber wrote:
>> On 23/05/2019 07:35, Chris Johns wrote:
>>> On 23/5/19 12:25 am, Sebastian Huber wrote:
>>>> We definitely need a repository to store the requirements files (Doorstop,
>>>> YAML). This is the first thing we have to know. If it later turns out that the
>>>> choice was bad, we can still remove it from one repository and do a subtree
>>>> import in another.
>>> I suggest you use personal repos under your name to experiment with. It will
>>> give you more freedom and will not impact on the main repos until we know the
>>> direction.
>> Yes, we can do this. The drawback with this approach is that the work is a bit
>> more detached from the RTEMS development and will probably end up with a huge
>> patch set out of nothing.
> If we start with a single component and go from there we can monitor how it is
> evolving. If the approach is sensible, scalable and we like it we can move to
> the main repo. I assume you will post patches for view? I recommend this happens
> because a large merge becomes a simple move to the main repo. Yes buildbot will
> go nuts but we can discuss this Amar when the time comes.
Ok, we will work on a private repository first. I can add a branch to
https://git.rtems.org/sebh/rtems.git/
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
