Instructions to send a Patch
Vaibhav Gupta
vaibhavgupta40 at gmail.com
Wed May 29 02:24:32 UTC 2019
On Tue, May 28, 2019 at 9:54 PM Joel Sherrill <joel at rtems.org> wrote:
> Also the newlib community really appreciates it if we review the patches
> on the RTEMS development list first. When the patch is OK, then it can go
> to the newlib list.
Yeah, this is why I sent the patch on devel; for review.
> --joel
> On Mon, May 27, 2019 at 12:12 PM Vaibhav Gupta <vaibhavgupta40 at gmail.com>
> wrote:
>> Hello, okay I will keep that in mind.
>> But there is one problem with this patch then.
>> If i just copy-paste ndbm.h, db.h(needed by ndbm.h) and ndbm.c and make
>> the entry of ndbm.c in Makefile.am.
>> Then run 'autoreconf' to add the entry for ndbm.c in Makefile.in. And
>> then run `make` command. There will be compilation error.
>> Header files needed by libc/posic/*.c files are present in libc/include
>> directory. It is default path.
>> But ndbm.c also requires "hash.h" which is present inside "libc/search".
>> To over come it, i had to modify the entry of ndbm.c in Makefile.in and
>> add "-I (topr_srcdir)/search" to specify the compiler for alternative
>> source path.
>> The problem is, to modify Makefile.in there should be entry of ndbm.c .
>> And for that i need to run autoreconf command. Because of that multiple
>> files get modified and hence the patch size got bigger..
>> One solution can be that I should not use autoreconf and make manual
>> entries for ndbm.c in Makefile.in . Should I try that?
>> Because there is need to mention alternative source path for header
>> files, to compile ndbm.c.
>> Thankyou
>> Vaibhav Gupta
>> On Mon, 27 May, 2019, 7:38 PM Aditya Upadhyay, <aadit0402 at gmail.com>
>> wrote:
>>> Hi Vaibhav,
>>> You have sent a completely wrong patch. You do not need to include all
>>> these files what are existed there. You should generate a patch for
>>> your work like addition or modification or if you have added any other
>>> file.
>>> This patch should go to newlib mailing list. For your entire GSoC
>>> period, You will send patch to Newlib-Cygwin and For testing
>>> contributed methods, you will be adding testcases in rtems/testsuite.
>>> For testing those methods, you will have to apply patches to
>>> rtems-source-builder, see instructions here:
>>> https://docs.rtems.org/releases/rtemsdocs-4.10.2/share/rtems/html/started/started00036.html
>>> If you have not introduced yourself on newlib mailing list, then
>>> Introduce yourself there. Point your plan what you are going to do
>>> this GSoC Period. Though these are parts of Community bonding period.
>>> I appreciate your effort. This is just an initial phase of GSoC. You
>>> should take care of these things.
>>> Thanks,
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190529/0a051787/attachment-0001.html>
