Build FreeBSD: FAILED 6/rtems-x86_64.bset on x86_64-freebsd12.0 (x86_64-rtems6-gdb-ff4a4474eb-x86_64-freebsd12.0-1)
Fri May 31 10:11:54 UTC 2019
All the builds on FreeBSD 12 failed this week. The reason seems to be this:
grep -r ORIGINAL_AS_FOR_TARGET .
./gcc/config.log:ORIGINAL_AS_FOR_TARGET=''
./gcc/config.status:S["ORIGINAL_AS_FOR_TARGET"]=""
./gcc/as:ORIGINAL_AS_FOR_TARGET=""
./gcc/as:    original=$ORIGINAL_AS_FOR_TARGET
./gcc/collect-ld:ORIGINAL_AS_FOR_TARGET=""
./gcc/collect-ld:    original=$ORIGINAL_AS_FOR_TARGET
./gcc/nm:ORIGINAL_AS_FOR_TARGET=""
./gcc/nm:    original=$ORIGINAL_AS_FOR_TARGET
./gcc/Makefile:ORIGINAL_AS_FOR_TARGET =
I don't know why this variable is empty.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
