[PATCH] Add Test suite for inttypes.h (psxinttypes.exe) in testsuites/psxtests
Fri May 31 23:32:09 UTC 2019
On Thu, May 30, 2019 at 9:17 AM VARoDeK <vaibhavgupta40 at gmail.com> wrote:
Please use your full name in the git-user metadata.
>  testsuites/psxtests/Makefile.am               |   7 +
>  testsuites/psxtests/configure.ac              |   1 +
>  testsuites/psxtests/psxinttypes01/init.c      | 154 ++++++++++++++++++
>  .../psxtests/psxinttypes01/psxinttypes01.doc  |  57 +++++++
>  .../psxtests/psxinttypes01/psxinttypes01.scn  |  28 ++++
>  5 files changed, 247 insertions(+)
>  create mode 100644 testsuites/psxtests/psxinttypes01/init.c
>  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.doc
>  create mode 100644 testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
> index 749258cc0c..f619dd9ae9 100644
> --- a/testsuites/psxtests/Makefile.am
> +++ b/testsuites/psxtests/Makefile.am
> @@ -22,6 +22,13 @@ psx01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psx01) \
>         $(support_includes) -I$(top_srcdir)/include
>  endif
> +if TEST_psxinttypes01
> +psx_tests += psxinttypes01
> +psxinttypes01_SOURCES = psxinttypes01/init.c
> +psxinttypes01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxinttypes01) \
> +       $(support_includes)
> +endif
>  if HAS_POSIX
>  if TEST_psx02
>  psx_tests += psx02
> diff --git a/testsuites/psxtests/configure.ac b/testsuites/psxtests/configure.ac
> index cdd6ee7e4e..e032a6f5ec 100644
> --- a/testsuites/psxtests/configure.ac
> +++ b/testsuites/psxtests/configure.ac
> @@ -140,6 +140,7 @@ RTEMS_TEST_CHECK([psxtimes01])
>  RTEMS_TEST_CHECK([psxualarm])
>  RTEMS_TEST_CHECK([psxusleep])
>  RTEMS_TEST_CHECK([lib_a])
> +RTEMS_TEST_CHECK([psxinttypes01])
Should this be in alphabetical order with others?
>  AC_CONFIG_FILES([Makefile])
>  AC_OUTPUT
> diff --git a/testsuites/psxtests/psxinttypes01/init.c b/testsuites/psxtests/psxinttypes01/init.c
> new file mode 100644
> index 0000000000..1c6340afe2
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -0,0 +1,154 @@
> + *  @file
> + *  @brief Test suite for inttypes.h methods
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2019, Vaibhav Gupta
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/test.h>
> +#include <inttypes.h>
> +#include <stdio.h>
> +#include <errno.h>
> +#include <tmacros.h>
> +#include <stdint.h>
> +#include <stddef.h>
> +const char rtems_test_name[] = "PSXINTTYPE 01";
> +/* forward declarations to avoid warnings */
> +rtems_task Init(rtems_task_argument ignored);
> +  int       base     = 10;
> +  char     *nptr1    = "123abc";
> +  char     *endptr1  = NULL;
> +  wchar_t  *nptr2    = L"-123junk";
> +  wchar_t  *endptr2  = NULL;
> +  intmax_t  status1;
> +  uintmax_t status2;
> +  TEST_BEGIN();
> +  puts( "\nChecking invalid base value" );
> +  rtems_test_assert( base >=2 && base <= 36 );
This isn't testing anything of use.
> +  /*Test for strtoimax  */
> +  puts( "Strtoimax Testcases...." );
> +  puts( "Generating Status" );
> +  status1 = strtoimax( nptr1, &endptr1, base );
status1 isn't a status, use descriptive names
> +  rtems_test_assert( status1 != 0);
What should it be? 123?
> +  rtems_test_assert( base != EINVAL);
base isn't an output, so this doesn't make sense to me.
> +  puts( "Checking Garbage end of endptr" );
> +  rtems_test_assert( *endptr1 != '\0' );
> +  puts( "Checking Underflow Case" );
> +  rtems_test_assert( status1 >= INTMAX_MIN );
isn't' this true by definition?
> +  puts( "Checking Overflow Case" );
> +  rtems_test_assert( status1 <= INTMAX_MAX ) ;
ditto
> +  printf( "status = %jd \n" , status1 );
> +  /*Test for strtoumax  */
> +  puts( "Strtoumax Testcases...." );
> +  status2 = strtoumax( nptr1, &endptr1, base );
> +  rtems_test_assert( status2 != 0);
> +  rtems_test_assert( status2 <= UINTMAX_MAX );
> +  printf( "status = %ju \n", status2 );
> +  /*Test for wcstoimax  */
> +  puts( "Wcstoimax Testcases...." );
> +  status1 = wcstoimax( nptr2, &endptr2, base );
> +  rtems_test_assert( *endptr2 != '\0' );
> +  printf( "status = %jd \n", status1 );
> +  /*Test for wcstoumax  */
> +  puts( "wcstoumax Testcases...." );
> +  status2 = wcstoumax( nptr2, &endptr2, base );
> +  TEST_END();
> +  rtems_test_exit(0);
> +/* NOTICE: the clock driver is explicitly disabled */
> +#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
> +#define CONFIGURE_APPLICATION_NEEDS_CONSOLE_DRIVER
> +#define CONFIGURE_MAXIMUM_TASKS            1
> +#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> +#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> +#include <rtems/confdefs.h>
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.doc b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> index 0000000000..f9e0951786
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.doc
> @@ -0,0 +1,57 @@
> + *  @file
> + *  @brief Doc for Test suite for inttypes.h methods
> + * are met:
> +This File describes the concepts tested by this test suite.
> +inttypes.h - fixed size integer types
> +test suite name: PSXINTTYPE 01
> +- Checks for invalid base value
> +- Checks for Strtoimax Testcases
> +       - checks for Garbage end of endptr
> +       - checks for Underflow Case
> +       - checks for Overflow Case
> +- Checks for Strtoumax Test Cases
> +- Checks for Wcstoimax Testcases
> +- Checks for Wcstoumax Testcases
> diff --git a/testsuites/psxtests/psxinttypes01/psxinttypes01.scn b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> index 0000000000..cdd56b327d
> --- /dev/null
> +++ b/testsuites/psxtests/psxinttypes01/psxinttypes01.scn
> @@ -0,0 +1,28 @@
> +*** PSXINTTYPE 01 TEST ***
> +Checking invalid base value
> +Strtoimax Testcases....
> +Generating Status
> +Checking Garbage end of endptr
> +Checking Underflow Case
> +Checking Overflow Case
> +status = 123
> +Strtoumax Testcases....
> +Generating Status
> +status = 123
> +Wcstoimax Testcases....
> +Generating Status
> +status = -123
> +wcstoumax Testcases....
> +Generating Status
> +status = 18446744073709551493
> +*** END OF PSXINTTYPE 01 TEST ***
> 2.21.0
> devel mailing list
> devel at rtems.org
