Error during execution of testsuites on host OS, for ARM Architecture.
Joel Sherrill
joel at rtems.org
Fri May 3 01:02:58 UTC 2019
On Thu, May 2, 2019, 7:58 PM Chris Johns <chrisj at rtems.org> wrote:
> On 3 May 2019, at 10:55 am, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> I tried to post this earlier but was having outgoing mail problems.
> The command varies between versions of qemu. It is likely the rtems-tester
> configuration file
> for this BSP doesn't match the version of qemu you have built. This is
> from a shell script
> I use on an application. Notice the difference in arguments due to qemu
> version.
> #echo "-no-reboot -serial null -serial mon:stdio -net none -nographic -M
> xilinx-zynq-a9 -m 256M ${COVERAGE_ARG} -kernel ${1}"
> echo "-no-reboot -monitor none -serial stdio -net none -nographic -M
> Yes. The `rtems-test` command if configured to use the RSB built version
> of qemu.
> Do you know version is which command line
Not off hand. I recall being unable to build the default Qemu package so it
is probably the couverture one.
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20190502/7e998188/attachment-0002.html>
