[PATCH 16/98] doxygen: score: adjust doc in coresem.h to doxygen guidelines
    Sebastian Huber
    Tue May  7 05:39:21 UTC 2019
From: Andreas Dachsberger <andreas.dachsberger at embedded-brains.de>
 cpukit/include/rtems/score/coresem.h | 28 ++++++++++++++++------------
 1 file changed, 16 insertions(+), 12 deletions(-)
diff --git a/cpukit/include/rtems/score/coresem.h b/cpukit/include/rtems/score/coresem.h
index b44daf56aa..e1f22dc768 100644
--- a/cpukit/include/rtems/score/coresem.h
+++ b/cpukit/include/rtems/score/coresem.h
@@ -1,12 +1,14 @@
- *  @file
+ * @file
- *  @brief Data Associated with the Counting Semaphore Handler
+ * @ingroup RTEMSScoreSemaphore
- *  This include file contains all the constants and structures associated
- *  with the Counting Semaphore Handler.  A counting semaphore is the
- *  standard Dijkstra binary semaphore used to provide synchronization
- *  and mutual exclusion capabilities.
+ * @brief Data Associated with the Counting Semaphore Handler
+ * This include file contains all the constants and structures associated
+ * with the Counting Semaphore Handler.  A counting semaphore is the
+ * standard Dijkstra binary semaphore used to provide synchronization
+ * and mutual exclusion capabilities.
@@ -28,14 +30,16 @@ extern "C" {
 #endif
- *  @defgroup RTEMSScoreSemaphore Semaphore Handler
+ * @defgroup RTEMSScoreSemaphore Semaphore Handler
- *  @ingroup RTEMSScore
+ * @brief Semaphore Handler
- *  This handler encapsulates functionality which provides the foundation
- *  Semaphore services used in all of the APIs supported by RTEMS.
+ * This handler encapsulates functionality which provides the foundation
+ * Semaphore services used in all of the APIs supported by RTEMS.
  *  The following defines the control block used to manage each
@@ -51,7 +55,7 @@ typedef struct {
   uint32_t                    count;
 }   CORE_semaphore_Control;
 #ifdef __cplusplus
2.16.4
