[PATCH] riscv: Rename new *_clang.cfg file to *_clang.ccfg
Fri Nov 1 17:43:36 UTC 2019
On Fri, Nov 1, 2019 at 3:16 AM Hesham Almatary
<hesham.almatary at cl.cam.ac.uk> wrote:
> On Thu, 31 Oct 2019 at 08:52, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
> > On 29/10/2019 10:34, Hesham Almatary wrote:
> > > This is to hide the new BSPs from GCC builds when building
> > > all RISC-V BSPs with configure --target=riscv-rtems5
> > Can you still build the clang variants after this change?
> No. That's just a temporary fix to be able to build all riscv BSPs
> with until we have a better solution to conditionally add Clang flags.
Is it worth it to try to integrate support better in configure to
search for the ccfg files when clang is specified?
> > Sebastian Huber, embedded brains GmbH
> > Address : Dornierstr. 4, D-82178 Puchheim, Germany
> > Phone   : +49 89 189 47 41-16
> > Fax     : +49 89 189 47 41-09
> > E-Mail  : sebastian.huber at embedded-brains.de
> > PGP     : Public key available on request.
> > Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
> devel mailing list
> devel at rtems.org
