[PATCH rtems-littelvgl] Allow to build without drivers.
Christian Mauderer
christian.mauderer at embedded-brains.de
Tue Nov 5 11:56:03 UTC 2019
This is for example usefull if you want to build without libbsd.
lvgl.py | 8 +++++---
wscript | 7 +++++++
2 files changed, 12 insertions(+), 3 deletions(-)
diff --git a/lvgl.py b/lvgl.py
index 6d83c63..5452ed0 100644
--- a/lvgl.py
+++ b/lvgl.py
@@ -30,7 +30,7 @@ import os
import re
import rtems_waf.rtems as rtems
-def source_list():
+def source_list(bld):
mk_files = ['lvgl/src/lv_core/lv_core.mk',
'lvgl/src/lv_hal/lv_hal.mk',
'lvgl/src/lv_objx/lv_objx.mk',
@@ -38,7 +38,9 @@ def source_list():
'lvgl/src/lv_misc/lv_misc.mk',
'lvgl/src/lv_themes/lv_themes.mk',
'lvgl/src/lv_draw/lv_draw.mk',
- 'lv_drivers/display/display.mk']
+ if bld.env.DRIVERS:
+ mk_files.append('lv_drivers/display/display.mk')
sources = []
cflags = []
@@ -64,7 +66,7 @@ def source_list():
def build(bld):
- sources, includes = source_list()
+ sources, includes = source_list(bld)
includes.append('.')
objects = []
include_paths = []
diff --git a/wscript b/wscript
index 03e010c..ae91daa 100644
--- a/wscript
+++ b/wscript
@@ -43,8 +43,15 @@ def init(ctx):
def options(opt):
rtems.options(opt)
+ opt.add_option("--no-drivers",
+ action = "store_false",
+ default = True,
+ dest = "drivers",
+ help = "Build without lv_drivers." +
+ "Useful for building without libbsd.")
def configure(conf):
+ conf.env.DRIVERS = conf.options.drivers
rtems.configure(conf)
def build(bld):
2.16.4
