Performance problem with PyYAML
Fri Nov 8 10:33:53 UTC 2019
I experimented a bit with marshal, pickle, and ast.literal_eval. I think
that using a cache file is the way to go. An update evaluation based on
the mtime is quite fast. You need the YAML to X conversion only if a
build specification file changed or upon first use. We don't have to
store the cache file in the repository (could be 1MiB or more). See
attached example scripts.
My favourite is a conversion to pickle. It is supposed to be a stable
format and was also the fastest, about 0.1 seconds load time.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191108/a49690ab/attachment-0003.py>
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191108/a49690ab/attachment-0004.py>
Type: text/x-python
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191108/a49690ab/attachment-0005.py>
