[PATCH 02/13] psxtests: Avoid build system defined defines
    Sebastian Huber
    Fri Nov  8 14:02:50 UTC 2019
Update #3818.
 testsuites/psxtests/Makefile.am                   |   8 +-
 testsuites/psxtests/psxsignal03/init.c            | 252 +---------------------
 testsuites/psxtests/psxsignal03/psxsignal0ximpl.h | 234 ++++++++++++++++++++
 testsuites/psxtests/psxsignal04/init.c            |   2 +
 4 files changed, 241 insertions(+), 255 deletions(-)
 create mode 100644 testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
 create mode 100644 testsuites/psxtests/psxsignal04/init.c
diff --git a/testsuites/psxtests/Makefile.am b/testsuites/psxtests/Makefile.am
index 536b77f560..42d67e2fd9 100755
--- a/testsuites/psxtests/Makefile.am
+++ b/testsuites/psxtests/Makefile.am
@@ -842,8 +842,7 @@ psx_screens += psxsignal03/psxsignal03.scn
 psx_docs += psxsignal03/psxsignal03.doc
 psxsignal03_SOURCES = psxsignal03/init.c include/pmacros.h
 psxsignal03_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal03) \
-	$(support_includes) -I$(top_srcdir)/include \
-	-DUSE_USER_SIGNALS_PROCESS
+	$(support_includes) -I$(top_srcdir)/include
 endif
 endif
@@ -852,10 +851,9 @@ if TEST_psxsignal04
 psx_tests += psxsignal04
 psx_screens += psxsignal04/psxsignal04.scn
 psx_docs += psxsignal04/psxsignal04.doc
-psxsignal04_SOURCES = psxsignal03/init.c include/pmacros.h
+psxsignal04_SOURCES = psxsignal04/init.c include/pmacros.h
 psxsignal04_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_psxsignal04) \
-	-DUSE_REAL_TIME_SIGNALS_PROCESS
 endif
 endif
diff --git a/testsuites/psxtests/psxsignal03/init.c b/testsuites/psxtests/psxsignal03/init.c
index fcf7192664..bc9daf8bfb 100644
--- a/testsuites/psxtests/psxsignal03/init.c
+++ b/testsuites/psxtests/psxsignal03/init.c
@@ -1,250 +1,2 @@
- *  COPYRIGHT (c) 1989-2012.
- *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
-#include "config.h"
-#endif
-#if defined(USE_USER_SIGNALS_PROCESS)
-  #define TEST_NAME                "PSXSIGNAL 3"
-  #define TEST_STRING              "User Signals to Process"
-  #define SIGNAL_ONE               SIGUSR1
-  #define SIGNAL_TWO               SIGUSR2
-  #define SEND_SIGNAL(_sig)        kill( getpid(), _sig )
-  #define TO_PROCESS
-#elif defined(USE_REAL_TIME_SIGNALS_PROCESS)
-  #define TEST_NAME                "PSXSIGNAL 4"
-  #define TEST_STRING              "Real-Time Signals to Process"
-  #define SIGNAL_ONE               SIGRTMIN
-  #define SIGNAL_TWO               SIGRTMAX
-#elif defined(USE_USER_SIGNALS_THREAD)
-  #define TEST_NAME                "PSXSIGNAL 5"
-  #define TEST_STRING              "User Signals to Thread"
-  #define SEND_SIGNAL(_sig)        pthread_kill( id, _sig )
-  #define TO_THREAD
-#elif defined(USE_REAL_TIME_SIGNALS_THREAD)
-  #define TEST_STRING              "Real-Time Signals to Thread"
-  #define TO_THREAD
-#else
-  #error "Test Mode not defined"
-#endif
-#include <pmacros.h>
-#include <signal.h>
-#include <errno.h>
-#include <pthread.h>
-#include <sched.h>
-const char rtems_test_name[] = TEST_NAME;
-/* forward declarations to avoid warnings */
-void *POSIX_Init(void *argument);
-void *Test_Thread(void *arg);
-void Signal_handler(int signo, siginfo_t *info, void *arg);
-const char *signal_name(int signo);
-volatile bool      Signal_occurred;
-volatile pthread_t Signal_thread;
-static void block_all_signals(void)
-  int               sc;
-  sigset_t          mask;
-  sc = sigfillset( &mask );
-  rtems_test_assert( !sc );
-  sc = pthread_sigmask( SIG_BLOCK, &mask, NULL );
-  int        signo,
-  siginfo_t *info,
-  void      *arg
-  Signal_occurred = true;
-  Signal_thread   = pthread_self();
-  if (signo == SIGUSR1)
-    return "SIGUSR1";
-  if (signo == SIGUSR2)
-    return "SIGUSR2";
-  if (signo == SIGRTMIN)
-    return "SIGRTMIN";
-  if (signo == SIGRTMAX)
-    return "SIGRTMAX";
-  return "unknown-signal";
-  bool        blocked = *((bool *)arg);
-  const char *name;
-  int         sc;
-  sigset_t    mask;
-  sigset_t    wait_mask;
-  siginfo_t   info;
-  if ( blocked )
-    name = "SignalBlocked";
-  else
-    name = "SignalNotBlocked";
-  /* build unblocked mask */
-  sc = sigemptyset( &mask );
-  printf( "%s - Unblock %s\n", name, signal_name(SIGNAL_ONE) );
-  sc = sigaddset( &mask, SIGNAL_ONE );
-  if ( !blocked ) {
-    printf( "%s - Unblock %s\n", name, signal_name(SIGNAL_TWO) );
-    sc = sigaddset( &mask, SIGNAL_TWO );
-  /* unblocked signals */
-  sc = pthread_sigmask( SIG_UNBLOCK, &mask, NULL );
-  /* build wait mask */
-  sc = sigemptyset( &wait_mask );
-  sc = sigaddset( &wait_mask, SIGNAL_ONE );
-  /* wait for a signal */
-  memset( &info, 0, sizeof(info) );
-  printf( "%s - Wait for %s unblocked\n", name, signal_name(SIGNAL_ONE) );
-  sigwaitinfo( &wait_mask, &info );
-  printf( "%s - siginfo.si_signo=%d\n", name, info.si_signo );
-  printf( "%s - siginfo.si_code=%d\n", name, info.si_code );
-  /* FIXME: Instead of casting to (uintptr_t) and using PRIxPTR, we
-   * likely should use %p. However, this would render this test's
-   * behavior non-deterministic, because %p's behavior is
-   * "implementation defined" */
-  printf(
-    "%s - siginfo.si_value=0x%08" PRIxPTR "\n",
-    name,
-    (uintptr_t) info.si_value.sival_ptr
-  rtems_test_assert( info.si_signo == SIGNAL_TWO );
-  rtems_test_assert( info.si_code == SI_USER );
-  printf( "%s - exiting\n", name );
-  return NULL;
-void *POSIX_Init(
-  void *argument
-  int                 sc;
-  pthread_t           id;
-  struct sigaction    act;
-  bool                trueArg = true;
-  bool                falseArg = false;
-  struct timespec     delay_request;
-  TEST_BEGIN();
-  puts( "Init - Variation is: " TEST_STRING );
-  block_all_signals();
-  Signal_occurred = false;
-  act.sa_handler = NULL;
-  act.sa_sigaction = Signal_handler;
-  act.sa_flags   = SA_SIGINFO;
-  sigaction( SIGNAL_ONE, &act, NULL );
-  sigaction( SIGNAL_TWO, &act, NULL );
-  /* create threads */
-  sc = pthread_create( &id, NULL, Test_Thread, &falseArg );
-  sc = pthread_create( &id, NULL, Test_Thread, &trueArg );
-  puts( "Init - sleep - let threads settle - OK" );
-  delay_request.tv_sec = 0;
-  delay_request.tv_nsec = 5 * 100000000;
-  sc = nanosleep( &delay_request, NULL );
-  puts( "Init - sleep - SignalBlocked thread settle - OK" );
-  printf( "Init - sending %s - deliver to one thread\n",
-          signal_name(SIGNAL_TWO));
-  sc =  SEND_SIGNAL( SIGNAL_TWO );
-  printf( "Init - sending %s - deliver to other thread\n",
-  #if defined(TO_PROCESS)
-    printf( "Init - sending %s - expect EAGAIN\n", signal_name(SIGNAL_TWO) );
-    rtems_test_assert( sc == -1 );
-    rtems_test_assert( errno == EAGAIN );
-  #endif
-  puts( "Init - sleep - let thread report if it unblocked - OK" );
-  usleep(500000);
-  /* we are just sigwait'ing the signal, not delivering it */
-  rtems_test_assert( Signal_occurred == true );
-  TEST_END();
-  rtems_test_exit(0);
-  return NULL; /* just so the compiler thinks we returned something */
-/* configuration information */
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_MAXIMUM_POSIX_THREADS        3
-#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 1
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE
-#include <rtems/confdefs.h>
+#define USE_USER_SIGNALS_PROCESS
+#include "psxsignal0ximpl.h"
diff --git a/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h b/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
new file mode 100644
index 0000000000..6410be1020
--- /dev/null
+++ b/testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
@@ -0,0 +1,234 @@
+ *  COPYRIGHT (c) 1989-2012.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#if defined(USE_USER_SIGNALS_PROCESS)
+  #define TEST_NAME                "PSXSIGNAL 3"
+  #define TEST_STRING              "User Signals to Process"
+  #define SIGNAL_ONE               SIGUSR1
+  #define SIGNAL_TWO               SIGUSR2
+  #define SEND_SIGNAL(_sig)        kill( getpid(), _sig )
+  #define TO_PROCESS
+#elif defined(USE_REAL_TIME_SIGNALS_PROCESS)
+  #define TEST_NAME                "PSXSIGNAL 4"
+  #define TEST_STRING              "Real-Time Signals to Process"
+  #define SIGNAL_ONE               SIGRTMIN
+  #define SIGNAL_TWO               SIGRTMAX
+#else
+  #error "Test Mode not defined"
+#endif
+#include <pmacros.h>
+#include <signal.h>
+#include <errno.h>
+#include <pthread.h>
+#include <sched.h>
+const char rtems_test_name[] = TEST_NAME;
+/* forward declarations to avoid warnings */
+void *POSIX_Init(void *argument);
+void *Test_Thread(void *arg);
+void Signal_handler(int signo, siginfo_t *info, void *arg);
+const char *signal_name(int signo);
+volatile bool      Signal_occurred;
+volatile pthread_t Signal_thread;
+static void block_all_signals(void)
+  int               sc;
+  sigset_t          mask;
+  sc = sigfillset( &mask );
+  rtems_test_assert( !sc );
+  sc = pthread_sigmask( SIG_BLOCK, &mask, NULL );
+  int        signo,
+  siginfo_t *info,
+  void      *arg
+  Signal_occurred = true;
+  Signal_thread   = pthread_self();
+  if (signo == SIGUSR1)
+    return "SIGUSR1";
+  if (signo == SIGUSR2)
+    return "SIGUSR2";
+  if (signo == SIGRTMIN)
+    return "SIGRTMIN";
+  if (signo == SIGRTMAX)
+    return "SIGRTMAX";
+  return "unknown-signal";
+  bool        blocked = *((bool *)arg);
+  const char *name;
+  int         sc;
+  sigset_t    mask;
+  sigset_t    wait_mask;
+  siginfo_t   info;
+  if ( blocked )
+    name = "SignalBlocked";
+  else
+    name = "SignalNotBlocked";
+  /* build unblocked mask */
+  sc = sigemptyset( &mask );
+  printf( "%s - Unblock %s\n", name, signal_name(SIGNAL_ONE) );
+  sc = sigaddset( &mask, SIGNAL_ONE );
+  if ( !blocked ) {
+    printf( "%s - Unblock %s\n", name, signal_name(SIGNAL_TWO) );
+    sc = sigaddset( &mask, SIGNAL_TWO );
+  /* unblocked signals */
+  sc = pthread_sigmask( SIG_UNBLOCK, &mask, NULL );
+  /* build wait mask */
+  sc = sigemptyset( &wait_mask );
+  sc = sigaddset( &wait_mask, SIGNAL_ONE );
+  /* wait for a signal */
+  memset( &info, 0, sizeof(info) );
+  printf( "%s - Wait for %s unblocked\n", name, signal_name(SIGNAL_ONE) );
+  sigwaitinfo( &wait_mask, &info );
+  printf( "%s - siginfo.si_signo=%d\n", name, info.si_signo );
+  printf( "%s - siginfo.si_code=%d\n", name, info.si_code );
+  /* FIXME: Instead of casting to (uintptr_t) and using PRIxPTR, we
+   * likely should use %p. However, this would render this test's
+   * behavior non-deterministic, because %p's behavior is
+   * "implementation defined" */
+  printf(
+    "%s - siginfo.si_value=0x%08" PRIxPTR "\n",
+    name,
+    (uintptr_t) info.si_value.sival_ptr
+  rtems_test_assert( info.si_signo == SIGNAL_TWO );
+  rtems_test_assert( info.si_code == SI_USER );
+  printf( "%s - exiting\n", name );
+  return NULL;
+void *POSIX_Init(
+  void *argument
+  int                 sc;
+  pthread_t           id;
+  struct sigaction    act;
+  bool                trueArg = true;
+  bool                falseArg = false;
+  struct timespec     delay_request;
+  TEST_BEGIN();
+  puts( "Init - Variation is: " TEST_STRING );
+  block_all_signals();
+  Signal_occurred = false;
+  act.sa_handler = NULL;
+  act.sa_sigaction = Signal_handler;
+  act.sa_flags   = SA_SIGINFO;
+  sigaction( SIGNAL_ONE, &act, NULL );
+  sigaction( SIGNAL_TWO, &act, NULL );
+  /* create threads */
+  sc = pthread_create( &id, NULL, Test_Thread, &falseArg );
+  sc = pthread_create( &id, NULL, Test_Thread, &trueArg );
+  puts( "Init - sleep - let threads settle - OK" );
+  delay_request.tv_sec = 0;
+  delay_request.tv_nsec = 5 * 100000000;
+  sc = nanosleep( &delay_request, NULL );
+  puts( "Init - sleep - SignalBlocked thread settle - OK" );
+  printf( "Init - sending %s - deliver to one thread\n",
+          signal_name(SIGNAL_TWO));
+  sc =  SEND_SIGNAL( SIGNAL_TWO );
+  printf( "Init - sending %s - deliver to other thread\n",
+  #if defined(TO_PROCESS)
+    printf( "Init - sending %s - expect EAGAIN\n", signal_name(SIGNAL_TWO) );
+    rtems_test_assert( sc == -1 );
+    rtems_test_assert( errno == EAGAIN );
+  #endif
+  puts( "Init - sleep - let thread report if it unblocked - OK" );
+  usleep(500000);
+  /* we are just sigwait'ing the signal, not delivering it */
+  rtems_test_assert( Signal_occurred == true );
+  TEST_END();
+  rtems_test_exit(0);
+  return NULL; /* just so the compiler thinks we returned something */
+/* configuration information */
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_MAXIMUM_POSIX_THREADS        3
+#define CONFIGURE_MAXIMUM_POSIX_QUEUED_SIGNALS 1
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+#include <rtems/confdefs.h>
diff --git a/testsuites/psxtests/psxsignal04/init.c b/testsuites/psxtests/psxsignal04/init.c
index 0000000000..449634153a
--- /dev/null
+++ b/testsuites/psxtests/psxsignal04/init.c
@@ -0,0 +1,2 @@
+#define USE_REAL_TIME_SIGNALS_PROCESS
+#include "../psxsignal03/psxsignal0ximpl.h"
2.16.4
