[PATCH 00/13] Avoid build system defined defines
Sebastian Huber
Fri Nov 8 14:02:47 UTC 2019
Build system defined defines are quite bad. Firstly, they are invisible to code
indexing tools such as ctags and code anlaysers included in IDEs. Secondly,
they make the introduction of a new build system more complicated than
necessary. This patch set removes all build system defined defines from the
test.
Sebastian Huber (13):
tests: Remove superfluous SMPTESTS define
psxtests: Avoid build system defined defines
psxtmtests: Avoid build system defined defines
sptests: Avoid build system defined defines
spfatal16: Remove obsolete test program
sptests: Remove obsolete semaphore consume driver
libtests: Avoid build system defined defines
samples: Avoid build system defined defines
samples/paranoia: Remove <bsp.h> include
mptests/mp14: Make MAX_LONG_TEST_DURATION constant
ada/samples: Avoid build system defined defines
mptests: Avoid build system defined defines
testsuites/ada/samples/base_mp/node1/Makefile.am | 5 +-
testsuites/ada/samples/base_mp/node1/init.c | 2 +
testsuites/ada/samples/base_mp/node2/Makefile.am | 5 +-
testsuites/ada/samples/base_mp/node2/init.c | 2 +
testsuites/libtests/Makefile.am | 27 +-
testsuites/libtests/complex/docomplexl.c | 3 +
testsuites/libtests/dl06/init.c | 89 +-----
testsuites/libtests/dl06/initimpl.h | 88 ++++++
testsuites/libtests/dl06/pre-init.c | 2 +
testsuites/libtests/mathl/domathl.c | 3 +
testsuites/libtests/mouse01/init.c | 3 +-
testsuites/libtests/mouse01/serial_mouse_config.c | 2 +-
.../libtests/termios04/termios_testdriver_impl.h | 306 ++++++++++++++++++++
.../libtests/termios04/termios_testdriver_intr.c | 307 +--------------------
testsuites/libtests/termios05/init.c | 2 +-
.../libtests/termios05/termios_testdriver_task.c | 2 +
testsuites/libtests/termios06/init.c | 2 +-
testsuites/libtests/termios07/init.c | 2 +-
testsuites/libtests/termios08/init.c | 2 +-
testsuites/libtests/termios10/init.c | 192 +------------
testsuites/libtests/termios10/termios10impl.h | 191 +++++++++++++
testsuites/libtests/termios11/init.c | 2 +
testsuites/libtests/uid01/init.c | 3 +-
testsuites/libtests/uid01/serial_mouse_config.c | 2 +-
testsuites/mptests/Makefile.am | 108 ++++----
testsuites/mptests/configure.ac | 4 -
testsuites/mptests/mp01/init1.c | 2 +
testsuites/mptests/mp01/init2.c | 2 +
testsuites/mptests/mp01/{init.c => initimpl.h} | 0
testsuites/mptests/mp03/init1.c | 2 +
testsuites/mptests/mp03/init2.c | 2 +
testsuites/mptests/mp03/{init.c => initimpl.h} | 0
testsuites/mptests/mp04/init1.c | 2 +
testsuites/mptests/mp04/init2.c | 2 +
testsuites/mptests/mp04/{init.c => initimpl.h} | 0
testsuites/mptests/mp05/init1.c | 2 +
testsuites/mptests/mp05/init2.c | 2 +
testsuites/mptests/mp05/{init.c => initimpl.h} | 0
testsuites/mptests/mp06/init1.c | 2 +
testsuites/mptests/mp06/init2.c | 2 +
testsuites/mptests/mp06/{init.c => initimpl.h} | 0
testsuites/mptests/mp07/init1.c | 2 +
testsuites/mptests/mp07/init2.c | 2 +
testsuites/mptests/mp07/{init.c => initimpl.h} | 0
testsuites/mptests/mp08/init1.c | 2 +
testsuites/mptests/mp08/init2.c | 2 +
testsuites/mptests/mp08/{init.c => initimpl.h} | 0
testsuites/mptests/mp09/init1.c | 2 +
testsuites/mptests/mp09/init2.c | 2 +
testsuites/mptests/mp09/{init.c => initimpl.h} | 0
testsuites/mptests/mp10/init1.c | 2 +
testsuites/mptests/mp10/init2.c | 2 +
testsuites/mptests/mp10/{init.c => initimpl.h} | 0
testsuites/mptests/mp11/init1.c | 2 +
testsuites/mptests/mp11/init2.c | 2 +
testsuites/mptests/mp11/{init.c => initimpl.h} | 0
testsuites/mptests/mp12/init1.c | 2 +
testsuites/mptests/mp12/init2.c | 2 +
testsuites/mptests/mp12/{init.c => initimpl.h} | 0
testsuites/mptests/mp13/init1.c | 2 +
testsuites/mptests/mp13/init2.c | 2 +
testsuites/mptests/mp13/{init.c => initimpl.h} | 0
testsuites/mptests/mp14/init1.c | 2 +
testsuites/mptests/mp14/init2.c | 2 +
testsuites/mptests/mp14/{init.c => initimpl.h} | 6 +
testsuites/psxtests/Makefile.am | 8 +-
testsuites/psxtests/psxsignal03/init.c | 252 +----------------
testsuites/psxtests/psxsignal03/psxsignal0ximpl.h | 234 ++++++++++++++++
testsuites/psxtests/psxsignal04/init.c | 2 +
testsuites/psxtmtests/Makefile.am | 12 +-
testsuites/psxtmtests/psxtmcond08/init.c | 184 +-----------
.../psxtmtests/psxtmcond08/psxtmcond08impl.h | 182 ++++++++++++
testsuites/psxtmtests/psxtmcond09/init.c | 2 +
testsuites/psxtmtests/psxtmcond10/init.c | 2 +
testsuites/samples/Makefile.am | 10 +-
testsuites/samples/base_mp/init1.c | 2 +
testsuites/samples/base_mp/init2.c | 2 +
testsuites/samples/base_mp/{init.c => initimpl.h} | 0
testsuites/samples/paranoia/paranoia.c | 5 +-
testsuites/smptests/Makefile.am | 14 +-
testsuites/sptests/Makefile.am | 67 ++---
testsuites/sptests/sp27/init.c | 146 +---------
testsuites/sptests/sp27/sp27impl.h | 145 ++++++++++
testsuites/sptests/sp27a/init.c | 2 +
testsuites/sptests/sp52/init.c | 140 +---------
testsuites/sptests/sp52/sp52impl.h | 139 ++++++++++
testsuites/sptests/sp53/init.c | 2 +
testsuites/sptests/sp65/init.c | 154 +----------
testsuites/sptests/sp65/sp65impl.h | 153 ++++++++++
testsuites/sptests/sp66/init.c | 2 +
testsuites/sptests/spfatal16/spfatal16.doc | 19 --
testsuites/sptests/spfatal16/spfatal16.scn | 3 -
testsuites/sptests/spfatal16/testcase.h | 29 --
testsuites/sptests/spfatal_support/consume_sems.c | 63 -----
testsuites/sptests/spfatal_support/system.h | 11 -
testsuites/sptests/spintrcritical01/init.c | 157 +----------
.../spintrcritical01/spintrcritical01impl.h | 155 +++++++++++
testsuites/sptests/spintrcritical02/init.c | 2 +
testsuites/sptests/spintrcritical03/init.c | 2 +
testsuites/sptests/spintrcritical04/init.c | 2 +
testsuites/sptests/spintrcritical05/init.c | 2 +
testsuites/sptests/spintrcritical06/init.c | 149 +---------
.../spintrcritical06/spintrcritical06impl.h | 147 ++++++++++
testsuites/sptests/spintrcritical07/init.c | 2 +
testsuites/sptests/spintrcritical11/init.c | 98 +------
.../spintrcritical11/spintrcritical11impl.h | 96 +++++++
testsuites/sptests/spintrcritical12/init.c | 2 +
testsuites/sptests/spintrcritical13/init.c | 122 +-------
.../spintrcritical13/spintrcritical13impl.h | 120 ++++++++
testsuites/sptests/spintrcritical14/init.c | 2 +
testsuites/support/include/tmacros.h | 10 +-
testsuites/tmtests/Makefile.am | 28 +-
testsuites/tmtests/tm02/task1.c | 189 +------------
testsuites/tmtests/tm02/tm02impl.h | 187 +++++++++++++
testsuites/tmtests/tm03/task1.c | 180 +-----------
testsuites/tmtests/tm03/tm03impl.h | 178 ++++++++++++
testsuites/tmtests/tm31/task1.c | 2 +
testsuites/tmtests/tm32/task1.c | 2 +
testsuites/tmtests/tm33/task1.c | 2 +
testsuites/tmtests/tm34/task1.c | 2 +
testsuites/tmtests/tm35/task1.c | 2 +
testsuites/tmtests/tm36/task1.c | 2 +
122 files changed, 2602 insertions(+), 2640 deletions(-)
create mode 100644 testsuites/ada/samples/base_mp/node1/init.c
create mode 100644 testsuites/ada/samples/base_mp/node2/init.c
create mode 100644 testsuites/libtests/dl06/initimpl.h
create mode 100644 testsuites/libtests/dl06/pre-init.c
create mode 100644 testsuites/libtests/termios04/termios_testdriver_impl.h
create mode 100644 testsuites/libtests/termios05/termios_testdriver_task.c
create mode 100644 testsuites/libtests/termios10/termios10impl.h
create mode 100644 testsuites/libtests/termios11/init.c
create mode 100644 testsuites/mptests/mp01/init1.c
create mode 100644 testsuites/mptests/mp01/init2.c
rename testsuites/mptests/mp01/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp03/init1.c
create mode 100644 testsuites/mptests/mp03/init2.c
rename testsuites/mptests/mp03/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp04/init1.c
create mode 100644 testsuites/mptests/mp04/init2.c
rename testsuites/mptests/mp04/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp05/init1.c
create mode 100644 testsuites/mptests/mp05/init2.c
rename testsuites/mptests/mp05/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp06/init1.c
create mode 100644 testsuites/mptests/mp06/init2.c
rename testsuites/mptests/mp06/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp07/init1.c
create mode 100644 testsuites/mptests/mp07/init2.c
rename testsuites/mptests/mp07/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp08/init1.c
create mode 100644 testsuites/mptests/mp08/init2.c
rename testsuites/mptests/mp08/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp09/init1.c
create mode 100644 testsuites/mptests/mp09/init2.c
rename testsuites/mptests/mp09/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp10/init1.c
create mode 100644 testsuites/mptests/mp10/init2.c
rename testsuites/mptests/mp10/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp11/init1.c
create mode 100644 testsuites/mptests/mp11/init2.c
rename testsuites/mptests/mp11/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp12/init1.c
create mode 100644 testsuites/mptests/mp12/init2.c
rename testsuites/mptests/mp12/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp13/init1.c
create mode 100644 testsuites/mptests/mp13/init2.c
rename testsuites/mptests/mp13/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/mptests/mp14/init1.c
create mode 100644 testsuites/mptests/mp14/init2.c
rename testsuites/mptests/mp14/{init.c => initimpl.h} (97%)
create mode 100644 testsuites/psxtests/psxsignal03/psxsignal0ximpl.h
create mode 100644 testsuites/psxtests/psxsignal04/init.c
create mode 100644 testsuites/psxtmtests/psxtmcond08/psxtmcond08impl.h
create mode 100644 testsuites/psxtmtests/psxtmcond09/init.c
create mode 100644 testsuites/psxtmtests/psxtmcond10/init.c
create mode 100644 testsuites/samples/base_mp/init1.c
create mode 100644 testsuites/samples/base_mp/init2.c
rename testsuites/samples/base_mp/{init.c => initimpl.h} (100%)
create mode 100644 testsuites/sptests/sp27/sp27impl.h
create mode 100644 testsuites/sptests/sp27a/init.c
create mode 100644 testsuites/sptests/sp52/sp52impl.h
create mode 100644 testsuites/sptests/sp53/init.c
create mode 100644 testsuites/sptests/sp65/sp65impl.h
create mode 100644 testsuites/sptests/sp66/init.c
delete mode 100644 testsuites/sptests/spfatal16/spfatal16.doc
delete mode 100644 testsuites/sptests/spfatal16/spfatal16.scn
delete mode 100644 testsuites/sptests/spfatal16/testcase.h
delete mode 100644 testsuites/sptests/spfatal_support/consume_sems.c
create mode 100644 testsuites/sptests/spintrcritical01/spintrcritical01impl.h
create mode 100644 testsuites/sptests/spintrcritical02/init.c
create mode 100644 testsuites/sptests/spintrcritical03/init.c
create mode 100644 testsuites/sptests/spintrcritical04/init.c
create mode 100644 testsuites/sptests/spintrcritical05/init.c
create mode 100644 testsuites/sptests/spintrcritical06/spintrcritical06impl.h
create mode 100644 testsuites/sptests/spintrcritical07/init.c
create mode 100644 testsuites/sptests/spintrcritical11/spintrcritical11impl.h
create mode 100644 testsuites/sptests/spintrcritical12/init.c
create mode 100644 testsuites/sptests/spintrcritical13/spintrcritical13impl.h
create mode 100644 testsuites/sptests/spintrcritical14/init.c
create mode 100644 testsuites/tmtests/tm02/tm02impl.h
create mode 100644 testsuites/tmtests/tm03/tm03impl.h
create mode 100644 testsuites/tmtests/tm31/task1.c
create mode 100644 testsuites/tmtests/tm32/task1.c
create mode 100644 testsuites/tmtests/tm33/task1.c
create mode 100644 testsuites/tmtests/tm34/task1.c
create mode 100644 testsuites/tmtests/tm35/task1.c
create mode 100644 testsuites/tmtests/tm36/task1.c
2.16.4
