[PATCH 07/13] libtests: Avoid build system defined defines
Sebastian Huber
Fri Nov 8 14:02:55 UTC 2019
Update #3818.
testsuites/libtests/Makefile.am | 27 +-
testsuites/libtests/complex/docomplexl.c | 3 +
testsuites/libtests/dl06/init.c | 89 +-----
testsuites/libtests/dl06/initimpl.h | 88 ++++++
testsuites/libtests/dl06/pre-init.c | 2 +
testsuites/libtests/mathl/domathl.c | 3 +
testsuites/libtests/mouse01/init.c | 3 +-
testsuites/libtests/mouse01/serial_mouse_config.c | 2 +-
.../libtests/termios04/termios_testdriver_impl.h | 306 ++++++++++++++++++++
.../libtests/termios04/termios_testdriver_intr.c | 307 +--------------------
testsuites/libtests/termios05/init.c | 2 +-
.../libtests/termios05/termios_testdriver_task.c | 2 +
testsuites/libtests/termios06/init.c | 2 +-
testsuites/libtests/termios07/init.c | 2 +-
testsuites/libtests/termios08/init.c | 2 +-
testsuites/libtests/termios10/init.c | 192 +------------
testsuites/libtests/termios10/termios10impl.h | 191 +++++++++++++
testsuites/libtests/termios11/init.c | 2 +
testsuites/libtests/uid01/init.c | 3 +-
testsuites/libtests/uid01/serial_mouse_config.c | 2 +-
20 files changed, 621 insertions(+), 609 deletions(-)
create mode 100644 testsuites/libtests/dl06/initimpl.h
create mode 100644 testsuites/libtests/dl06/pre-init.c
create mode 100644 testsuites/libtests/termios04/termios_testdriver_impl.h
create mode 100644 testsuites/libtests/termios05/termios_testdriver_task.c
create mode 100644 testsuites/libtests/termios10/termios10impl.h
create mode 100644 testsuites/libtests/termios11/init.c
diff --git a/testsuites/libtests/Makefile.am b/testsuites/libtests/Makefile.am
index 1300a5f669..171e2e3b65 100644
--- a/testsuites/libtests/Makefile.am
+++ b/testsuites/libtests/Makefile.am
@@ -219,7 +219,7 @@ lib_screens += complex/complex.scn
complex_SOURCES = complex/init.c complex/docomplex.c \
complex/docomplexf.c complex/docomplexl.c
complex_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_complex) \
- $(support_includes) -DNO_LONG_DOUBLE
+ $(support_includes)
complex_LDADD = -lm $(LDADD)
endif
@@ -483,7 +483,7 @@ dl06-pre-tar.o: dl06-pre-tar.c dl06-pre-tar.h
$(AM_V_CC)$(COMPILE) -c -o $@ $<
dl06-pre-init.o: dl06-pre-tar.o
$(AM_V_CC)$(COMPILE) $(dl06_CPPFLAGS) $(CPU_CFLAGS) $(AM_CFLAGS) \
- -DDL06_PRE -c -o $@ $(srcdir)/dl06/init.c
+ -c -o $@ $(srcdir)/dl06/pre-init.c
dl06.pre: dl06-pre-init.o dl06/dl06-dl-load.o dl06-pre-tar.o
@rm -f $@ dl06-sym.o
$(AM_V_CCLD)$(LINK.c) $(CPU_CFLAGS) $(AM_CFLAGS) $(AM_LDFLAGS) -o $@ $+ $(LDADD)
@@ -985,8 +985,7 @@ lib_tests += mathl
lib_screens += mathl/mathl.scn
mathl_SOURCES = mathl/init.c mathl/domathl.c
mathl_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_mathl) \
- $(support_includes) -I$(top_srcdir)/math \
- -DNO_LONG_DOUBLE
+ $(support_includes) -I$(top_srcdir)/math
mathl_LDADD = -lm $(LDADD)
endif
@@ -1044,7 +1043,7 @@ lib_docs += mouse01/mouse01.doc
mouse01_SOURCES = mouse01/init.c mouse01/serial_mouse_config.c \
mouse01/msmouse.c termios04/termios_testdriver_intr.c
mouse01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_mouse01) \
- $(support_includes) -I$(top_srcdir)/termios04
endif
if TEST_nanosleep
@@ -1448,9 +1447,9 @@ lib_tests += termios05
lib_screens += termios05/termios05.scn
lib_docs += termios05/termios05.doc
termios05_SOURCES = termios05/init.c \
- termios04/termios_testdriver_intr.c
+ termios05/termios_testdriver_task.c
termios05_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios05) \
- $(support_includes) -I$(top_srcdir)/termios04 -DTASK_DRIVEN
endif
if TEST_termios06
@@ -1460,7 +1459,7 @@ lib_docs += termios06/termios06.doc
termios06_SOURCES = termios06/init.c \
termios03/termios_testdriver_polled.c termios06/test_pppd.c
termios06_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios06) \
- $(support_includes) -I$(top_srcdir)/termios03
endif
if TEST_termios07
@@ -1470,7 +1469,7 @@ lib_docs += termios07/termios07.doc
termios07_SOURCES = termios07/init.c \
termios07_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios07) \
endif
if TEST_termios08
@@ -1480,7 +1479,7 @@ lib_docs += termios08/termios08.doc
termios08_SOURCES = termios08/init.c \
termios08_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios08) \
endif
if TEST_termios09
@@ -1499,17 +1498,17 @@ lib_docs += termios10/termios10.doc
termios10_SOURCES = termios10/init.c
termios10_SOURCES += termios03/termios_testdriver_polled.c
termios10_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios10) \
endif
if TEST_termios11
lib_tests += termios11
lib_screens += termios11/termios11.scn
lib_docs += termios11/termios11.doc
-termios11_SOURCES = termios10/init.c
+termios11_SOURCES = termios11/init.c
termios11_SOURCES += termios04/termios_testdriver_intr.c
termios11_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_termios11) \
- $(support_includes) -I$(top_srcdir)/termios04 -DINTERRUPT_DRIVEN
endif
if TEST_top
@@ -1560,7 +1559,7 @@ lib_docs += uid01/uid01.doc
uid01_SOURCES = uid01/init.c uid01/serial_mouse_config.c \
uid01/msmouse.c termios04/termios_testdriver_intr.c
uid01_CPPFLAGS = $(AM_CPPFLAGS) $(TEST_FLAGS_uid01) \
endif
if TEST_unlink
diff --git a/testsuites/libtests/complex/docomplexl.c b/testsuites/libtests/complex/docomplexl.c
index 87817c7773..8b8317b3ff 100644
--- a/testsuites/libtests/complex/docomplexl.c
+++ b/testsuites/libtests/complex/docomplexl.c
@@ -14,6 +14,9 @@
#include "config.h"
#endif
+/* FIXME: Why is this defined? */
+#define NO_LONG_DOUBLE
#ifdef NO_LONG_DOUBLE
#define PROVIDE_EMPTY_FUNC
#endif
diff --git a/testsuites/libtests/dl06/init.c b/testsuites/libtests/dl06/init.c
index 6f03d01843..413ebf0d11 100644
--- a/testsuites/libtests/dl06/init.c
+++ b/testsuites/libtests/dl06/init.c
@@ -1,88 +1 @@
- * Copyright (c) 2014 Chris Johns <chrisj at rtems.org>. All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
-#ifdef HAVE_CONFIG_H
- #include "config.h"
-#endif
-#include "tmacros.h"
-#include <errno.h>
-#include <string.h>
-#include <stdint.h>
-#include <unistd.h>
-#include <rtems/rtl/rtl.h>
-#include <rtems/untar.h>
-#include "dl-load.h"
-const char rtems_test_name[] = "libdl (RTL) 6";
-/* forward declarations to avoid warnings */
-static rtems_task Init(rtems_task_argument argument);
-#if DL06_PRE
-#include "dl06-pre-tar.h"
-#else
-#include "dl06-tar.h"
-#endif
-#define TARFILE_START dl06_tar
-#define TARFILE_SIZE dl06_tar_size
-static int test(void)
- int ret;
- ret = dl_load_test();
- if (ret)
- rtems_test_exit(ret);
- return 0;
-static void Init(rtems_task_argument arg)
- int te;
- TEST_BEGIN();
- te = Untar_FromMemory((void *)TARFILE_START, (size_t)TARFILE_SIZE);
- if (te != 0)
- printf("untar failed: %d\n", te);
- rtems_test_exit(1);
- exit (1);
- test();
- TEST_END();
- rtems_test_exit(0);
-#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
-#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
-#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
-#define CONFIGURE_MAXIMUM_TASKS 1
-#define CONFIGURE_MAXIMUM_SEMAPHORES 1
-#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
-#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
-#define CONFIGURE_INIT_TASK_STACK_SIZE (8U * 1024U)
-#define CONFIGURE_INIT_TASK_ATTRIBUTES (RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT)
-#include <rtems/confdefs.h>
+#include "initimpl.h"
diff --git a/testsuites/libtests/dl06/initimpl.h b/testsuites/libtests/dl06/initimpl.h
new file mode 100644
index 0000000000..6f03d01843
--- /dev/null
+++ b/testsuites/libtests/dl06/initimpl.h
@@ -0,0 +1,88 @@
+ * Copyright (c) 2014 Chris Johns <chrisj at rtems.org>. All rights reserved.
+#ifdef HAVE_CONFIG_H
+ #include "config.h"
+#endif
+#include "tmacros.h"
+#include <errno.h>
+#include <string.h>
+#include <stdint.h>
+#include <unistd.h>
+#include <rtems/rtl/rtl.h>
+#include <rtems/untar.h>
+#include "dl-load.h"
+const char rtems_test_name[] = "libdl (RTL) 6";
+/* forward declarations to avoid warnings */
+static rtems_task Init(rtems_task_argument argument);
+#if DL06_PRE
+#include "dl06-pre-tar.h"
+#else
+#include "dl06-tar.h"
+#endif
+#define TARFILE_START dl06_tar
+#define TARFILE_SIZE dl06_tar_size
+static int test(void)
+ int ret;
+ ret = dl_load_test();
+ if (ret)
+ rtems_test_exit(ret);
+ return 0;
+static void Init(rtems_task_argument arg)
+ int te;
+ TEST_BEGIN();
+ te = Untar_FromMemory((void *)TARFILE_START, (size_t)TARFILE_SIZE);
+ if (te != 0)
+ printf("untar failed: %d\n", te);
+ rtems_test_exit(1);
+ exit (1);
+ test();
+ TEST_END();
+ rtems_test_exit(0);
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_LIBIO_MAXIMUM_FILE_DESCRIPTORS 4
+#define CONFIGURE_MAXIMUM_TASKS 1
+#define CONFIGURE_MAXIMUM_SEMAPHORES 1
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#define CONFIGURE_INIT_TASK_STACK_SIZE (8U * 1024U)
+#define CONFIGURE_INIT_TASK_ATTRIBUTES (RTEMS_DEFAULT_ATTRIBUTES | RTEMS_FLOATING_POINT)
+#include <rtems/confdefs.h>
diff --git a/testsuites/libtests/dl06/pre-init.c b/testsuites/libtests/dl06/pre-init.c
index 0000000000..6dc232a574
--- /dev/null
+++ b/testsuites/libtests/dl06/pre-init.c
@@ -0,0 +1,2 @@
+#define DL06_PRE 1
diff --git a/testsuites/libtests/mathl/domathl.c b/testsuites/libtests/mathl/domathl.c
index d0758dcc74..0781577d28 100644
--- a/testsuites/libtests/mathl/domathl.c
+++ b/testsuites/libtests/mathl/domathl.c
@@ -14,6 +14,9 @@
#include "config.h"
#endif
#endif
diff --git a/testsuites/libtests/mouse01/init.c b/testsuites/libtests/mouse01/init.c
index 8b71615d6b..b20afe121c 100644
--- a/testsuites/libtests/mouse01/init.c
+++ b/testsuites/libtests/mouse01/init.c
@@ -22,7 +22,7 @@
#include <sys/ioctl.h>
#include <unistd.h>
#include <rtems/mw_uid.h>
-#include "termios_testdriver_intr.h"
+#include "../termios04/termios_testdriver_intr.h"
const char rtems_test_name[] = "MOUSE 1";
@@ -151,7 +151,6 @@ rtems_task Init(
/* configuration information */
#include <rtems/serial_mouse.h>
/* NOTICE: the clock driver is explicitly disabled */
diff --git a/testsuites/libtests/mouse01/serial_mouse_config.c b/testsuites/libtests/mouse01/serial_mouse_config.c
index 09e420a3f2..798cbf3a3b 100644
--- a/testsuites/libtests/mouse01/serial_mouse_config.c
+++ b/testsuites/libtests/mouse01/serial_mouse_config.c
@@ -17,7 +17,7 @@
extern const char *Mouse_Type_Short;
diff --git a/testsuites/libtests/termios04/termios_testdriver_impl.h b/testsuites/libtests/termios04/termios_testdriver_impl.h
index 0000000000..53764fb9da
--- /dev/null
+++ b/testsuites/libtests/termios04/termios_testdriver_impl.h
@@ -0,0 +1,306 @@
+ * @file
+ * This file contains a test fixture termios device driver
+ * COPYRIGHT (c) 1989-2012.
+ * On-Line Applications Research Corporation (OAR).
+#include "config.h"
+#endif
+#include <rtems/libio.h>
+#include <stdlib.h>
+#include <termios.h>
+#include <rtems/termiostypes.h>
+#include <rtems/dumpbuf.h>
+#include "termios_testdriver_intr.h"
+void termios_test_driver_wait_for_tx_to_complete(void);
+rtems_timer_service_routine Rx_ISR(
+ rtems_id ignored_id,
+ void *ignored_address
+rtems_timer_service_routine Tx_ISR(
+ssize_t termios_test_driver_write_helper(
+ int port,
+ const char *buf,
+ size_t len
+int termios_test_driver_set_attributes(
+ int minor,
+ const struct termios *t
+#if defined(TASK_DRIVEN)
+ int termios_test_driver_inbyte_nonblocking(int port);
+#endif
+/* global variables */
+rtems_id Rx_Timer;
+rtems_id Tx_Timer;
+#define TX_MAX 1024
+uint8_t Tx_Buffer[TX_MAX];
+int Tx_Index = 0;
+struct rtems_termios_tty *Ttyp;
+ rtems_task_wake_after( 2 * rtems_clock_get_ticks_per_second() );
+void termios_test_driver_dump_tx(const char *c)
+ termios_test_driver_wait_for_tx_to_complete();
+ printf( "%s %d characters\n", c, Tx_Index );
+ rtems_print_buffer( Tx_Buffer, Tx_Index );
+ Tx_Index = 0;
+const uint8_t *Rx_Buffer;
+int Rx_Index = 0;
+int Rx_Length = 0;
+bool Rx_FirstTime = true;
+bool Rx_EnqueueNow = false;
+ int termios_test_driver_inbyte_nonblocking( int port )
+ if ( Rx_FirstTime == true ) {
+ Rx_FirstTime = false;
+ return -1;
+ if ( Rx_Index >= Rx_Length )
+ return -1;
+ return Rx_Buffer[ Rx_Index++ ];
+#endif
+ uint8_t ch;
+ return;
+ ch = Rx_Buffer[ Rx_Index++ ];
+ rtems_termios_enqueue_raw_characters (Ttyp, (char *)&ch, 1);
+ #if defined(TASK_DRIVEN)
+ rtems_termios_rxirq_occured(Ttyp);
+ #endif
+ (void) rtems_timer_fire_after( Rx_Timer, 10, Rx_ISR, NULL );
+ rtems_termios_dequeue_characters (Ttyp, 1);
+ (void) rtems_timer_fire_after( Tx_Timer, 10, Tx_ISR, NULL );
+void termios_test_driver_set_rx_enqueue_now(
+ bool value
+ Rx_EnqueueNow = value;
+void termios_test_driver_set_rx(
+ const void *p,
+ size_t len
+ Rx_Buffer = p;
+ Rx_Length = len;
+ Rx_Index = 0;
+ if ( Rx_EnqueueNow == false) {
+ return;
+ do {
+ uint8_t ch;
+ } while (Rx_Index < Rx_Length );
+ int port,
+ const char *buf,
+ size_t len
+ if (len > 0) {
+ Tx_Buffer[Tx_Index++] = buf[0];
+ return 0;
+ * Set Attributes Handler
+ int minor,
+ return 0;
+ * Test Device Driver Entry Points
+rtems_device_driver termios_test_driver_initialize(
+ rtems_device_major_number major,
+ rtems_device_minor_number minor,
+ void *arg
+ rtems_termios_initialize();
+ * Register Device Names
+ (void) rtems_io_register_name( TERMIOS_TEST_DRIVER_DEVICE_NAME, major, 0 );
+ return RTEMS_SUCCESSFUL;
+static int first_open(int major, int minor, void *arg)
+ rtems_status_code status;
+ status = rtems_timer_create(rtems_build_name('T', 'M', 'R', 'X'), &Rx_Timer);
+ if ( status != RTEMS_SUCCESSFUL )
+ rtems_fatal_error_occurred(1);
+ status = rtems_timer_create(rtems_build_name('T', 'M', 'T', 'X'), &Tx_Timer);
+ return 0;
+static int last_close(int major, int minor, void *arg)
+ status = rtems_timer_cancel(Rx_Timer);
+ status = rtems_timer_cancel(Tx_Timer);
+ status = rtems_timer_delete(Rx_Timer);
+ status = rtems_timer_delete(Tx_Timer);
+ return 0;
+rtems_device_driver termios_test_driver_open(
+ void * arg
+ rtems_status_code sc;
+ rtems_libio_open_close_args_t *args = arg;
+ static const rtems_termios_callbacks Callbacks = {
+ first_open, /* firstOpen */
+ last_close, /* lastClose */
+ termios_test_driver_inbyte_nonblocking,/* pollRead */
+ #else
+ NULL, /* pollRead */
+ #endif
+ termios_test_driver_write_helper, /* write */
+ termios_test_driver_set_attributes, /* setAttributes */
+ NULL, /* stopRemoteTx */
+ NULL, /* startRemoteTx */
+ TERMIOS_TASK_DRIVEN /* outputUsesInterrupts */
+ #else
+ 0 /* outputUsesInterrupts */
+ #endif
+ if ( minor > 2 ) {
+ puts( "ERROR - Termios_testdriver - only 1 minor supported" );
+ sc = rtems_termios_open (major, minor, arg, &Callbacks);
+ directive_failed( sc, "termios open" );
+ Ttyp = args->iop->data1; /* Keep cookie returned by termios_open */
+rtems_device_driver termios_test_driver_close(
+ void * arg
+ return rtems_termios_close (arg);
+rtems_device_driver termios_test_driver_read(
+ void * arg
+ return rtems_termios_read (arg);
+rtems_device_driver termios_test_driver_write(
+ void * arg
+ return rtems_termios_write (arg);
+rtems_device_driver termios_test_driver_control(
+ void * arg
+ return rtems_termios_ioctl (arg);
diff --git a/testsuites/libtests/termios04/termios_testdriver_intr.c b/testsuites/libtests/termios04/termios_testdriver_intr.c
index 53764fb9da..5946c29a4e 100644
--- a/testsuites/libtests/termios04/termios_testdriver_intr.c
+++ b/testsuites/libtests/termios04/termios_testdriver_intr.c
@@ -1,306 +1 @@
- * @file
- * This file contains a test fixture termios device driver
- * COPYRIGHT (c) 1989-2012.
- * On-Line Applications Research Corporation (OAR).
-#include "config.h"
-#endif
-#include <rtems/libio.h>
-#include <stdlib.h>
-#include <termios.h>
-#include <rtems/termiostypes.h>
-#include <rtems/dumpbuf.h>
-void termios_test_driver_wait_for_tx_to_complete(void);
-rtems_timer_service_routine Rx_ISR(
- rtems_id ignored_id,
- void *ignored_address
-rtems_timer_service_routine Tx_ISR(
-ssize_t termios_test_driver_write_helper(
- int port,
- const char *buf,
- size_t len
-int termios_test_driver_set_attributes(
- int minor,
- const struct termios *t
-#if defined(TASK_DRIVEN)
- int termios_test_driver_inbyte_nonblocking(int port);
-#endif
-/* global variables */
-rtems_id Rx_Timer;
-rtems_id Tx_Timer;
-#define TX_MAX 1024
-uint8_t Tx_Buffer[TX_MAX];
-int Tx_Index = 0;
-struct rtems_termios_tty *Ttyp;
- rtems_task_wake_after( 2 * rtems_clock_get_ticks_per_second() );
-void termios_test_driver_dump_tx(const char *c)
- termios_test_driver_wait_for_tx_to_complete();
- printf( "%s %d characters\n", c, Tx_Index );
- rtems_print_buffer( Tx_Buffer, Tx_Index );
- Tx_Index = 0;
-const uint8_t *Rx_Buffer;
-int Rx_Index = 0;
-int Rx_Length = 0;
-bool Rx_FirstTime = true;
-bool Rx_EnqueueNow = false;
- int termios_test_driver_inbyte_nonblocking( int port )
- if ( Rx_FirstTime == true ) {
- Rx_FirstTime = false;
- return -1;
- if ( Rx_Index >= Rx_Length )
- return -1;
- return Rx_Buffer[ Rx_Index++ ];
-#endif
- uint8_t ch;
- return;
- ch = Rx_Buffer[ Rx_Index++ ];
- rtems_termios_enqueue_raw_characters (Ttyp, (char *)&ch, 1);
- #if defined(TASK_DRIVEN)
- rtems_termios_rxirq_occured(Ttyp);
- #endif
- (void) rtems_timer_fire_after( Rx_Timer, 10, Rx_ISR, NULL );
- rtems_termios_dequeue_characters (Ttyp, 1);
- (void) rtems_timer_fire_after( Tx_Timer, 10, Tx_ISR, NULL );
-void termios_test_driver_set_rx_enqueue_now(
- bool value
- Rx_EnqueueNow = value;
-void termios_test_driver_set_rx(
- const void *p,
- size_t len
- Rx_Buffer = p;
- Rx_Length = len;
- Rx_Index = 0;
- if ( Rx_EnqueueNow == false) {
- return;
- do {
- uint8_t ch;
- } while (Rx_Index < Rx_Length );
- int port,
- const char *buf,
- size_t len
- if (len > 0) {
- Tx_Buffer[Tx_Index++] = buf[0];
- return 0;
- * Set Attributes Handler
- int minor,
- return 0;
- * Test Device Driver Entry Points
-rtems_device_driver termios_test_driver_initialize(
- rtems_device_major_number major,
- rtems_device_minor_number minor,
- void *arg
- rtems_termios_initialize();
- * Register Device Names
- (void) rtems_io_register_name( TERMIOS_TEST_DRIVER_DEVICE_NAME, major, 0 );
- return RTEMS_SUCCESSFUL;
-static int first_open(int major, int minor, void *arg)
- rtems_status_code status;
- status = rtems_timer_create(rtems_build_name('T', 'M', 'R', 'X'), &Rx_Timer);
- if ( status != RTEMS_SUCCESSFUL )
- rtems_fatal_error_occurred(1);
- status = rtems_timer_create(rtems_build_name('T', 'M', 'T', 'X'), &Tx_Timer);
- return 0;
-static int last_close(int major, int minor, void *arg)
- status = rtems_timer_cancel(Rx_Timer);
- status = rtems_timer_cancel(Tx_Timer);
- status = rtems_timer_delete(Rx_Timer);
- status = rtems_timer_delete(Tx_Timer);
- return 0;
-rtems_device_driver termios_test_driver_open(
- void * arg
- rtems_status_code sc;
- rtems_libio_open_close_args_t *args = arg;
- static const rtems_termios_callbacks Callbacks = {
- first_open, /* firstOpen */
- last_close, /* lastClose */
- termios_test_driver_inbyte_nonblocking,/* pollRead */
- #else
- NULL, /* pollRead */
- #endif
- termios_test_driver_write_helper, /* write */
- termios_test_driver_set_attributes, /* setAttributes */
- NULL, /* stopRemoteTx */
- NULL, /* startRemoteTx */
- TERMIOS_TASK_DRIVEN /* outputUsesInterrupts */
- #else
- 0 /* outputUsesInterrupts */
- #endif
- if ( minor > 2 ) {
- puts( "ERROR - Termios_testdriver - only 1 minor supported" );
- sc = rtems_termios_open (major, minor, arg, &Callbacks);
- directive_failed( sc, "termios open" );
- Ttyp = args->iop->data1; /* Keep cookie returned by termios_open */
-rtems_device_driver termios_test_driver_close(
- void * arg
- return rtems_termios_close (arg);
-rtems_device_driver termios_test_driver_read(
- void * arg
- return rtems_termios_read (arg);
-rtems_device_driver termios_test_driver_write(
- void * arg
- return rtems_termios_write (arg);
-rtems_device_driver termios_test_driver_control(
- void * arg
- return rtems_termios_ioctl (arg);
+#include "termios_testdriver_impl.h"
diff --git a/testsuites/libtests/termios05/init.c b/testsuites/libtests/termios05/init.c
index 089123dbd6..6b980cc7af 100644
--- a/testsuites/libtests/termios05/init.c
+++ b/testsuites/libtests/termios05/init.c
@@ -13,7 +13,7 @@
#include <tmacros.h>
#include "test_support.h"
#include <sys/types.h>
#include <sys/stat.h>
diff --git a/testsuites/libtests/termios05/termios_testdriver_task.c b/testsuites/libtests/termios05/termios_testdriver_task.c
index 0000000000..e1b31810a7
--- /dev/null
+++ b/testsuites/libtests/termios05/termios_testdriver_task.c
@@ -0,0 +1,2 @@
+#define TASK_DRIVEN
+#include "../termios04/termios_testdriver_impl.h"
diff --git a/testsuites/libtests/termios06/init.c b/testsuites/libtests/termios06/init.c
index 6ed8ac73ff..ead88e5e39 100644
--- a/testsuites/libtests/termios06/init.c
+++ b/testsuites/libtests/termios06/init.c
@@ -13,7 +13,7 @@
-#include "termios_testdriver_polled.h"
+#include "../termios03/termios_testdriver_polled.h"
diff --git a/testsuites/libtests/termios07/init.c b/testsuites/libtests/termios07/init.c
index 7acd48b49b..f3d3500333 100644
--- a/testsuites/libtests/termios07/init.c
+++ b/testsuites/libtests/termios07/init.c
@@ -13,7 +13,7 @@
diff --git a/testsuites/libtests/termios08/init.c b/testsuites/libtests/termios08/init.c
index 34f9d23757..b6aa59e2ba 100644
--- a/testsuites/libtests/termios08/init.c
+++ b/testsuites/libtests/termios08/init.c
@@ -13,7 +13,7 @@
diff --git a/testsuites/libtests/termios10/init.c b/testsuites/libtests/termios10/init.c
index ca5de97f24..8655879500 100644
--- a/testsuites/libtests/termios10/init.c
+++ b/testsuites/libtests/termios10/init.c
@@ -1,191 +1 @@
- * COPYRIGHT (c) 1989-2012,2019.
- * SPDX-License-Identifier: BSD-2-Clause
-#endif
-#include <tmacros.h>
-#include "test_support.h"
-#ifdef INTERRUPT_DRIVEN
-const char rtems_test_name[] = "TERMIOS 11 -- Interrupt driven";
-#else
-const char rtems_test_name[] = "TERMIOS 10 -- Polled";
-#endif
-#include <sys/types.h>
-#include <sys/stat.h>
-#include <errno.h>
-#include <fcntl.h>
-#include <signal.h>
-int Test_fd;
-static void open_it(void)
- Test_fd = open( TERMIOS_TEST_DRIVER_DEVICE_NAME, O_RDWR );
- rtems_test_assert( Test_fd != -1 );
-static void change_lflag( const char *desc, int mask, int new )
- int rc;
- struct termios attr;
- if (desc) {
- printf( "Changing c_lflag to: %s\n", desc );
- rc = tcgetattr( Test_fd, &attr );
- rtems_test_assert( rc == 0 );
- attr.c_lflag &= ~mask;
- attr.c_lflag |= new;
- rc = tcsetattr( Test_fd, TCSANOW, &attr );
-static void read_it(ssize_t expected, int expected_intr)
- ssize_t rc;
- char buf[32];
- rtems_test_assert( expected <= sizeof(buf) );
- rc = read( Test_fd, buf, expected );
- if (expected_intr) {
- rtems_test_assert( rc == -1 );
- rtems_test_assert( errno == EINTR );
- } else {
- if ( expected != rc )
- printf( "ERROR - expected=%zd rc=%zd\n", expected, rc );
- rtems_test_assert( expected == rc );
-static void close_it(void)
- int rc;
- rc = close( Test_fd );
-volatile int sigint_occurred = 0;
-volatile int sigquit_occurred = 0;
-static void sigint_handler(int signo)
- rtems_test_assert(signo == SIGINT);
- sigint_occurred = 1;
-static void sigquit_handler(int signo)
- rtems_test_assert(signo == SIGQUIT);
- sigquit_occurred = 1;
-static void test_read_for_signal(
- const char *description,
- int isig_value,
- char c,
- int sigint_expected,
- int sigquit_expected
- char expected[3];
- printf("Test read for %s\n", description);
- expected[0] = c;
- expected[1] = '\n'; /* in canonical mode, so need \n for read to return */
- expected[2] = '\0';
- sigint_occurred = 0;
- sigquit_occurred = 0;
- open_it();
- change_lflag(NULL, ISIG, isig_value);
- termios_test_driver_set_rx( expected, 2 );
- read_it(1, (sigint_expected || sigquit_expected));
- rtems_test_assert(sigint_occurred == sigint_expected);
- rtems_test_assert(sigquit_occurred == sigquit_expected);
- close_it();
- * Use a POSIX init thread so signals are enabled.
-static void *POSIX_Init(void *argument)
- int rc;
- TEST_BEGIN();
- signal(SIGINT, sigint_handler);
- signal(SIGQUIT, sigquit_handler);
- puts( "Exercise default ISIG handler with ISIG enabled");
- test_read_for_signal("VKILL - no signals", ISIG, '\003', 0, 0);
- test_read_for_signal("VQUIT - no signals", ISIG, '\034', 0, 0);
- puts( "Exercise POSIX ISIG handler with ISIG enabled");
- rc = rtems_termios_register_isig_handler(rtems_termios_posix_isig_handler);
- test_read_for_signal("VKILL - signal caught", ISIG, '\003', 1, 0);
- test_read_for_signal("VQUIT - signal caught", ISIG, '\034', 0, 1);
- rc = rtems_termios_register_isig_handler(rtems_termios_default_isig_handler);
- test_read_for_signal("VKILL - signal caught", ISIG, '\003', 0, 0);
- test_read_for_signal("VQUIT - signal caught", ISIG, '\034', 0, 0);
- puts( "Exercise POSIX ISIG handler with ISIG disabled");
- test_read_for_signal("VKILL - signal caught", 0, '\003', 0, 0);
- test_read_for_signal("VQUIT - signal caught", 0, '\034', 0, 0);
- TEST_END();
-/* configuration information */
-#define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
- TERMIOS_TEST_DRIVER_TABLE_ENTRY
-/* we need to be able to open the test device */
-#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
-#define CONFIGURE_MAXIMUM_TIMERS 2
-#define CONFIGURE_POSIX_INIT_THREAD_TABLE
-/* end of file */
+#include "termios10impl.h"
diff --git a/testsuites/libtests/termios10/termios10impl.h b/testsuites/libtests/termios10/termios10impl.h
index 0000000000..a01f203857
--- /dev/null
+++ b/testsuites/libtests/termios10/termios10impl.h
@@ -0,0 +1,191 @@
+ * COPYRIGHT (c) 1989-2012,2019.
+ * SPDX-License-Identifier: BSD-2-Clause
+#endif
+#include <tmacros.h>
+#include "test_support.h"
+#ifdef INTERRUPT_DRIVEN
+const char rtems_test_name[] = "TERMIOS 11 -- Interrupt driven";
+#else
+const char rtems_test_name[] = "TERMIOS 10 -- Polled";
+#endif
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <errno.h>
+#include <fcntl.h>
+#include <signal.h>
+int Test_fd;
+static void open_it(void)
+ Test_fd = open( TERMIOS_TEST_DRIVER_DEVICE_NAME, O_RDWR );
+ rtems_test_assert( Test_fd != -1 );
+static void change_lflag( const char *desc, int mask, int new )
+ int rc;
+ struct termios attr;
+ if (desc) {
+ printf( "Changing c_lflag to: %s\n", desc );
+ rc = tcgetattr( Test_fd, &attr );
+ rtems_test_assert( rc == 0 );
+ attr.c_lflag &= ~mask;
+ attr.c_lflag |= new;
+ rc = tcsetattr( Test_fd, TCSANOW, &attr );
+static void read_it(ssize_t expected, int expected_intr)
+ ssize_t rc;
+ char buf[32];
+ rtems_test_assert( expected <= sizeof(buf) );
+ rc = read( Test_fd, buf, expected );
+ if (expected_intr) {
+ rtems_test_assert( rc == -1 );
+ rtems_test_assert( errno == EINTR );
+ } else {
+ if ( expected != rc )
+ printf( "ERROR - expected=%zd rc=%zd\n", expected, rc );
+ rtems_test_assert( expected == rc );
+static void close_it(void)
+ int rc;
+ rc = close( Test_fd );
+volatile int sigint_occurred = 0;
+volatile int sigquit_occurred = 0;
+static void sigint_handler(int signo)
+ rtems_test_assert(signo == SIGINT);
+ sigint_occurred = 1;
+static void sigquit_handler(int signo)
+ rtems_test_assert(signo == SIGQUIT);
+ sigquit_occurred = 1;
+static void test_read_for_signal(
+ const char *description,
+ int isig_value,
+ char c,
+ int sigint_expected,
+ int sigquit_expected
+ char expected[3];
+ printf("Test read for %s\n", description);
+ expected[0] = c;
+ expected[1] = '\n'; /* in canonical mode, so need \n for read to return */
+ expected[2] = '\0';
+ sigint_occurred = 0;
+ sigquit_occurred = 0;
+ open_it();
+ change_lflag(NULL, ISIG, isig_value);
+ termios_test_driver_set_rx( expected, 2 );
+ read_it(1, (sigint_expected || sigquit_expected));
+ rtems_test_assert(sigint_occurred == sigint_expected);
+ rtems_test_assert(sigquit_occurred == sigquit_expected);
+ close_it();
+ * Use a POSIX init thread so signals are enabled.
+static void *POSIX_Init(void *argument)
+ int rc;
+ TEST_BEGIN();
+ signal(SIGINT, sigint_handler);
+ signal(SIGQUIT, sigquit_handler);
+ puts( "Exercise default ISIG handler with ISIG enabled");
+ test_read_for_signal("VKILL - no signals", ISIG, '\003', 0, 0);
+ test_read_for_signal("VQUIT - no signals", ISIG, '\034', 0, 0);
+ puts( "Exercise POSIX ISIG handler with ISIG enabled");
+ rc = rtems_termios_register_isig_handler(rtems_termios_posix_isig_handler);
+ test_read_for_signal("VKILL - signal caught", ISIG, '\003', 1, 0);
+ test_read_for_signal("VQUIT - signal caught", ISIG, '\034', 0, 1);
+ rc = rtems_termios_register_isig_handler(rtems_termios_default_isig_handler);
+ test_read_for_signal("VKILL - signal caught", ISIG, '\003', 0, 0);
+ test_read_for_signal("VQUIT - signal caught", ISIG, '\034', 0, 0);
+ puts( "Exercise POSIX ISIG handler with ISIG disabled");
+ test_read_for_signal("VKILL - signal caught", 0, '\003', 0, 0);
+ test_read_for_signal("VQUIT - signal caught", 0, '\034', 0, 0);
+ TEST_END();
+/* configuration information */
+#define CONFIGURE_APPLICATION_EXTRA_DRIVERS \
+ TERMIOS_TEST_DRIVER_TABLE_ENTRY
+/* we need to be able to open the test device */
+#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
+#define CONFIGURE_MAXIMUM_TIMERS 2
+#define CONFIGURE_POSIX_INIT_THREAD_TABLE
+/* end of file */
diff --git a/testsuites/libtests/termios11/init.c b/testsuites/libtests/termios11/init.c
index 0000000000..3492a62753
--- /dev/null
+++ b/testsuites/libtests/termios11/init.c
@@ -0,0 +1,2 @@
+#define INTERRUPT_DRIVEN
+#include "../termios10/termios10impl.h"
diff --git a/testsuites/libtests/uid01/init.c b/testsuites/libtests/uid01/init.c
index 85b8f447cd..f71c0023ec 100644
--- a/testsuites/libtests/uid01/init.c
+++ b/testsuites/libtests/uid01/init.c
@@ -21,7 +21,7 @@
#include <unistd.h>
const char rtems_test_name[] = "UID 1";
@@ -123,7 +123,6 @@ rtems_task Init(
diff --git a/testsuites/libtests/uid01/serial_mouse_config.c b/testsuites/libtests/uid01/serial_mouse_config.c
index 63840b117b..78c8602257 100644
--- a/testsuites/libtests/uid01/serial_mouse_config.c
+++ b/testsuites/libtests/uid01/serial_mouse_config.c
@@ -25,7 +25,7 @@
2.16.4
