On 9/11/19 10:36 am, Joel Sherrill wrote: > Looks like a failing in the GDB configure magic which finds libiconv Sadly this is the case. The idea of /usr/local does not seem to be supported. Check the RSB's freebsd.py support to see if the path is being set correctly. This should end up in the generated script that runs the build. I hope this helps. Chris
