psxfenv01 fails to compile for RISCV
Jiri Gaisler
jiri at gaisler.se
Sat Nov 9 21:26:00 UTC 2019
On 11/9/19 8:38 PM, Jiri Gaisler wrote:
> On 11/9/19 7:57 PM, Joel Sherrill wrote:
>> On Sat, Nov 9, 2019, 12:40 PM Jiri Gaisler <jiri at gaisler.se
>> <mailto:jiri at gaisler.se>> wrote:
>> I get this error for psxfenv01 with the latest RTEMS and RSB build:
>> riscv-rtems5-gcc -DHAVE_CONFIG_H -I.
>> -I/home/jiri/ibm/src/rtems/rtems/c/src/../../testsuites/psxtests
>> -I.
>> -I/home/jiri/src/rtems/riscvmp/riscv-rtems5/c/griscv/include
>> -I/home/jiri/ibm/src/rtems/rtems/cpukit/include
>> -I/home/jiri/ibm/src/rtems/rtems/cpukit/score/cpu/riscv/include
>> -I/home/jiri/src/rtems/riscvmp/riscv-rtems5/c/griscv/lib/libbsp/riscv/griscv/include
>> -I/home/jiri/ibm/src/rtems/rtems/bsps/include
>> -I/home/jiri/ibm/src/rtems/rtems/bsps/riscv/include
>> -I/home/jiri/ibm/src/rtems/rtems/bsps/riscv/griscv/include
>> -DT_FILE_NAME='"init.c"'
>> -I/home/jiri/ibm/src/rtems/rtems/c/src/../../testsuites/psxtests/../support/include
>> -march=rv32imafd -mabi=ilp32d -O2 -g -ffunction-sections
>> -fdata-sections
>> -Wall -Wmissing-prototypes -Wimplicit-function-declaration
>> -Wstrict-prototypes -Wnested-externs -MT
>> psxfenv01/psxfenv01-init.o -MD
>> -MP -MF psxfenv01/.deps/psxfenv01-init.Tpo -c -o
>> psxfenv01/psxfenv01-init.o `test -f 'psxfenv01/init.c' || echo
>> '/home/jiri/ibm/src/rtems/rtems/c/src/../../testsuites/psxtests/'`psxfenv01/init.c
>> In file included from
>> /home/jiri/src/rtems/5/riscv-rtems5/include/fenv.h:15,
>> from
>> /home/jiri/ibm/src/rtems/rtems/c/src/../../testsuites/psxtests/psxfenv01/init.c:42:
>> In function 'Init':
>> /home/jiri/ibm/src/rtems/rtems/c/src/../../testsuites/psxtests/psxfenv01/init.c:71:18:
>> error: 'fe_dfl_env_p' undeclared (first use in this function);
>> did you
>> mean 'fe_dfl_env'?
>> 71 | r = fesetenv(FE_DFL_ENV);
>> note: each undeclared identifier is reported only once for each
>> function
>> it appears in
>> Makefile:10569: recipe for target 'psxfenv01/psxfenv01-init.o' failed
>> make[5]: *** [psxfenv01/psxfenv01-init.o] Error 1
>> make[5]: Leaving directory
>> '/home/jiri/src/rtems/riscvmp/riscv-rtems5/c/griscv/testsuites/psxtests'
>> Makefile:663: recipe for target 'psxtests' failed
>> make[4]: *** [psxtests] Error 2
>> make[4]: Leaving directory
>> '/home/jiri/src/rtems/riscvmp/riscv-rtems5/c/griscv/testsuites'
>> Makefile:1222: recipe for target 'testsuites' failed
>> make[3]: *** [testsuites] Error 2
>> make[3]: Leaving directory
>> '/home/jiri/src/rtems/riscvmp/riscv-rtems5/c/griscv'
>> Makefile:716: recipe for target 'all-recursive' failed
>> make[2]: *** [all-recursive] Error 1
>> make[2]: Leaving directory
>> Makefile:289: recipe for target 'all-recursive' failed
>> make[1]: *** [all-recursive] Error 1
>> make[1]: Leaving directory
>> '/home/jiri/src/rtems/riscvmp/riscv-rtems5/c'
>> Makefile:410: recipe for target 'all-recursive' failed
>> make: *** [all-recursive] Error 1
>> jiri at office:~/src/rtems/riscvmp$
>> I thought I fixed this in the upstream newlib.
>> https://sourceware.org/git/gitweb.cgi?p=newlib-cygwin.git;a=commit;h=9e06ba1ac310c5a2392bb9d150e4686bbb118d6c
>> Either I didn't really fix it or your newlib is a bit old.
>> Did Sebastian bump 5's newlib recently? I recall a binutils bump.
> My RSB is in sync with git head, and I rebuilt the tool-chain 2 hours
> ago. The installed fenv.h for RISCV ends with:
> typedef size_t fenv_t;
> typedef size_t fexcept_t;
> extern const fenv_t fe_dfl_env;
> #define FE_DFL_ENV fe_dfl_env_p
> #endif /* _FENV_H_ */
> fe_dfl_env_p seems to be missing it's declaration ...?
After looking at it in more detail, the newlib used in RSB head for
5/rtems-riscv is 6661a67, which is from July 30. The commit that fixes
fenv.h is pushed October 9. So we need to bump the newlib version to
something after this date, or pull in a patch that fixes it. I will fix
it locally for my build tree for now ...
Jiri.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191109/a4269f80/attachment.html>
