[PATCH 1/2] riscv: preliminarily support for libdl
Hesham Almatary Hesham.Almatary at cl.cam.ac.uk
Mon Nov 11 12:29:15 UTC 2019
Support for targets compiled with -fno-pic and -mno-relax
 cpukit/configure.ac                           |   2 +-
 cpukit/libdl/rtl-elf.h                        |   2 +-
 cpukit/libdl/rtl-mdreloc-riscv.c              | 435 ++++++++++++++++++
 .../cpu/riscv/include/machine/elf_machdep.h   | 144 ++++++
 testsuites/libtests/configure.ac              |   2 +-
 5 files changed, 582 insertions(+), 3 deletions(-)
 create mode 100644 cpukit/libdl/rtl-mdreloc-riscv.c
 create mode 100644 cpukit/score/cpu/riscv/include/machine/elf_machdep.h
diff --git a/cpukit/configure.ac b/cpukit/configure.ac
index 5fd0f51d0f..1db9b047a2 100644
--- a/cpukit/configure.ac
+++ b/cpukit/configure.ac
@@ -307,7 +307,7 @@ AM_CONDITIONAL([RPCTOOLS],[test "$RPCGEN" = rpcgen \
 # reloc backends
 AC_MSG_CHECKING([whether CPU supports libdl])
 case $RTEMS_CPU in
-  arm | i386 | m68k | mips | moxie | powerpc | sparc)
+  arm | i386 | m68k | mips | moxie | powerpc | riscv | sparc)
    HAVE_LIBDL=yes ;;
   # bfin has an issue to resolve with libdl. See ticket #2252
   bfin)
diff --git a/cpukit/libdl/rtl-elf.h b/cpukit/libdl/rtl-elf.h
index 660b0c47b4..3bbc0bd9ee 100644
--- a/cpukit/libdl/rtl-elf.h
+++ b/cpukit/libdl/rtl-elf.h
@@ -31,7 +31,7 @@ extern "C" {
  * Do not add '()'. Leave plain.
-#if defined(__powerpc64__) || defined(__arch64__)
+#if defined(__powerpc64__) || defined(__arch64__) || (__riscv_xlen == 64)
 #define ELFSIZE 64
 #else
 #define ELFSIZE 32
diff --git a/cpukit/libdl/rtl-mdreloc-riscv.c b/cpukit/libdl/rtl-mdreloc-riscv.c
new file mode 100644
index 0000000000..e6778dcc90
--- /dev/null
+++ b/cpukit/libdl/rtl-mdreloc-riscv.c
@@ -0,0 +1,435 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (c) 2019 Hesham Almatary
+ * This software was developed by SRI International and the University of
+ * Cambridge Computer Laboratory (Department of Computer Science and
+ * Technology) under DARPA contract HR0011-18-C-0016 ("ECATS"), as part of the
+ * DARPA SSITH research programme.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+/* Part of the LLVM Project, under the Apache License v2.0 with LLVM Exceptions.
+ * See https://llvm.org/LICENSE.txt for license information.
+ * SPDX-License-Identifier: Apache-2.0 WITH LLVM-exception
+#include <sys/cdefs.h>
+#include <errno.h>
+#include <stdio.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <rtems/rtl/rtl.h>
+#include "rtl-elf.h"
+#include "rtl-error.h"
+#include <rtems/rtl/rtl-trace.h>
+#include "rtl-unwind.h"
+#include "rtl-unwind-dw2.h"
+uint32_t
+rtems_rtl_elf_section_flags (const rtems_rtl_obj* obj,
+                             const Elf_Shdr*      shdr) {
+  return 0;
+uint32_t
+rtems_rtl_elf_arch_parse_section (const rtems_rtl_obj* obj,
+                                  int                  section,
+                                  const char*          name,
+                                  const Elf_Shdr*      shdr,
+                                  const uint32_t       flags) {
+  (void) obj;
+  (void) section;
+  (void) name;
+  (void) shdr;
+  return flags;
+bool
+rtems_rtl_elf_arch_section_alloc (const rtems_rtl_obj* obj,
+                                  rtems_rtl_obj_sect*  sect) {
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+rtems_rtl_elf_arch_section_free (const rtems_rtl_obj* obj,
+  (void) obj;
+  (void) sect;
+  return false;
+bool
+rtems_rtl_elf_rel_resolve_sym (Elf_Word type) {
+  return true;
+size_t
+rtems_rtl_elf_relocate_tramp_max_size (void) {
+   * Disable by returning 0.
+  return 0;
+rtems_rtl_elf_rel_status
+rtems_rtl_elf_relocate_rel_tramp (rtems_rtl_obj*            obj,
+                                  const Elf_Rel*            rel,
+                                  const rtems_rtl_obj_sect* sect,
+                                  const char*               symname,
+                                  const Elf_Byte            syminfo,
+                                  const Elf_Word            symvalue) {
+  (void) obj;
+  (void) rel;
+  (void) sect;
+  (void) symname;
+  (void) syminfo;
+  (void) symvalue;
+  return rtems_rtl_elf_rel_no_error;
+// Extract bits V[Begin:End], where range is inclusive, and Begin must be < 63.
+static uint32_t extractBits(uint64_t v, uint32_t begin, uint32_t end) {
+  return (v & ((1ULL << (begin + 1)) - 1)) >> end;
+static int64_t SignExtend64(uint64_t val, unsigned bits) {
+  return (int64_t )(((int64_t) (val << (64 - bits))) >> (64 - bits));
+static void write16le(void *loc, uint16_t val) {
+  *((uint16_t *) loc) = val;
+static void write32le(void *loc, uint32_t val) {
+  *((uint32_t *) loc) = val;
+static void write64le(void *loc, uint64_t val) {
+  *((uint64_t *) loc) = val;
+static uint16_t read16le(void *loc) {
+  return *((uint16_t *) loc);
+static uint32_t read32le(void *loc) {
+  return *((uint32_t *) loc);
+static uint64_t read64le(void *loc) {
+  return *((uint64_t *) loc);
+static rtems_rtl_elf_rel_status
+rtems_rtl_elf_reloc_rela (rtems_rtl_obj*      obj,
+                          const Elf_Rela*           rela,
+                          const Elf_Word            symvalue,
+                          const bool parsing) {
+  Elf_Word *where;
+  Elf_Word  tmp;
+  Elf_Word addend = (Elf_Word) rela->r_addend;
+  Elf_Word local = 0;
+  char bits = (sizeof(Elf_Word) * 8);
+  where = (Elf_Addr *)(sect->base + rela->r_offset);
+  // Final PCREL value
+  Elf_Word pcrel_val = symvalue - ((Elf_Word) where);
+  if (syminfo == STT_SECTION) {
+    local = 1;
+  if (parsing) {
+  switch (ELF_R_TYPE(rela->r_info)) {
+  case R_TYPE(NONE):
+    break;
+  case R_TYPE(RVC_BRANCH): {
+    uint16_t insn = ((*where) & 0xFFFF) & 0xE383;
+    uint16_t imm8 = extractBits(pcrel_val, 8, 8) << 12;
+    uint16_t imm4_3 = extractBits(pcrel_val, 4, 3) << 10;
+    uint16_t imm7_6 = extractBits(pcrel_val, 7, 6) << 5;
+    uint16_t imm2_1 = extractBits(pcrel_val, 2, 1) << 3;
+    uint16_t imm5 = extractBits(pcrel_val, 5, 5) << 2;
+    insn |= imm8 | imm4_3 | imm7_6 | imm2_1 | imm5;
+    write16le(where, insn);
+  break;
+  case R_TYPE(RVC_JUMP): {
+    uint16_t insn = ((*where) & 0xFFFF) & 0xE003;
+    uint16_t imm11 = extractBits(pcrel_val, 11, 11) << 12;
+    uint16_t imm4 = extractBits(pcrel_val, 4, 4) << 11;
+    uint16_t imm9_8 = extractBits(pcrel_val, 9, 8) << 9;
+    uint16_t imm10 = extractBits(pcrel_val, 10, 10) << 8;
+    uint16_t imm6 = extractBits(pcrel_val, 6, 6) << 7;
+    uint16_t imm7 = extractBits(pcrel_val, 7, 7) << 6;
+    uint16_t imm3_1 = extractBits(pcrel_val, 3, 1) << 3;
+    insn |= imm11 | imm4 | imm9_8 | imm10 | imm6 | imm7 | imm3_1 | imm5;
+  break;
+  case R_TYPE(RVC_LUI): {
+    int64_t imm = SignExtend64(symvalue + 0x800, bits) >> 12;
+    if (imm == 0) { // `c.lui rd, 0` is illegal, convert to `c.li rd, 0`
+      write16le(where, (read16le(where) & 0x0F83) | 0x4000);
+    } else {
+      uint16_t imm17 = extractBits(symvalue + 0x800, 17, 17) << 12;
+      uint16_t imm16_12 = extractBits(symvalue + 0x800, 16, 12) << 2;
+      write16le(where, (read16le(where) & 0xEF83) | imm17 | imm16_12);
+  break;
+  case R_TYPE(JAL): {
+    uint32_t insn = read32le(where) & 0xFFF;
+    uint32_t imm20 = extractBits(pcrel_val, 20, 20) << 31;
+    uint32_t imm10_1 = extractBits(pcrel_val, 10, 1) << 21;
+    uint32_t imm11 = extractBits(pcrel_val, 11, 11) << 20;
+    uint32_t imm19_12 = extractBits(pcrel_val, 19, 12) << 12;
+    insn |= imm20 | imm10_1 | imm11 | imm19_12;
+    write32le(where, insn);
+  break;
+  case R_TYPE(BRANCH): {
+    uint32_t insn = read32le(where) & 0x1FFF07F;
+    uint32_t imm12 = extractBits(pcrel_val, 12, 12) << 31;
+    uint32_t imm10_5 = extractBits(pcrel_val, 10, 5) << 25;
+    uint32_t imm4_1 = extractBits(pcrel_val, 4, 1) << 8;
+    uint32_t imm11 = extractBits(pcrel_val, 11, 11) << 7;
+    insn |= imm12 | imm10_5 | imm4_1 | imm11;
+  break;
+  case R_TYPE(64):
+    write64le(where, symvalue);
+    break;
+  case R_TYPE(32):
+    write32le(where, symvalue);
+    break;
+  case R_TYPE(SET6):
+    *((uint8_t *) where) = (*where & 0xc0) | (symvalue & 0x3f);
+    break;
+  case R_TYPE(SET8):
+    *((uint8_t *) where) = symvalue;
+    break;
+  case R_TYPE(SET16):
+    write16le(where, symvalue);
+    break;
+  case R_TYPE(SET32):
+    break;
+  case R_TYPE(ADD8):
+    *((uint8_t *) where) = *((uint8_t *) where) + symvalue;
+    break;
+  case R_TYPE(ADD16):
+    write16le(where, read16le(where) + symvalue);
+    break;
+  case R_TYPE(ADD32):
+    write32le(where, read32le(where) + symvalue);
+    break;
+  case R_TYPE(ADD64):
+    write64le(where, read64le(where) + symvalue);
+    break;
+  case R_TYPE(SUB6):
+    *((uint8_t *) where) = (*where & 0xc0) | (((*where & 0x3f) - symvalue) & 0x3f);
+    break;
+  case R_TYPE(SUB8):
+    *((uint8_t *) where) = *((uint8_t *) where) - symvalue;
+    break;
+  case R_TYPE(SUB16):
+    write16le(where, read16le(where) - symvalue);
+    break;
+  case R_TYPE(SUB32):
+    write32le(where, read32le(where) - symvalue);
+    break;
+  case R_TYPE(SUB64):
+    write64le(where, read64le(where) - symvalue);
+    break;
+  case R_TYPE(32_PCREL): {
+    write32le(where, pcrel_val);
+    if (rtems_rtl_trace (RTEMS_RTL_TRACE_RELOC))
+      printf ("rtl: R_RISCV_32_PCREL %p @ %p in %s\n",
+              (void *) * (where), where, rtems_rtl_obj_oname (obj));
+  break;
+  case R_TYPE(PCREL_HI20): {
+    int64_t hi = SignExtend64(pcrel_val + 0x800, bits); //pcrel_val + 0x800;
+    write32le(where, (read32le(where) & 0xFFF) | (hi & 0xFFFFF000));
+  break;
+  case R_TYPE(GOT_HI20):
+  case R_TYPE(HI20): {
+    uint64_t hi = symvalue + 0x800;
+  break;
+  case R_TYPE(PCREL_LO12_I): {
+    uint64_t hi = (pcrel_val + 0x800) >> 12;
+    uint64_t lo = pcrel_val - (hi << 12);
+    write32le(where, (read32le(where) & 0xFFFFF) | ((lo & 0xFFF) << 20));
+  break;
+  case R_TYPE(LO12_I): {
+    uint64_t hi = (symvalue + 0x800) >> 12;
+    uint64_t lo = symvalue - (hi << 12);
+  break;
+  case R_TYPE(PCREL_LO12_S): {
+    uint32_t imm11_5 = extractBits(lo, 11, 5) << 25;
+    uint32_t imm4_0 = extractBits(lo, 4, 0) << 7;
+    write32le(where, (read32le(where) & 0x1FFF07F) | imm11_5 | imm4_0);
+  break;
+  case R_TYPE(LO12_S): {
+  break;
+  case R_TYPE(CALL_PLT):
+  case R_TYPE(CALL): {
+    int64_t hi20 = SignExtend64(pcrel_val + 0x800, bits);
+    int64_t lo = pcrel_val - (hi20 << 12);
+    write32le(((char *) where) + 4, (read32le(((char *) where) + 4) & 0xFFFFF) | ((lo & 0xFFF) << 20));
+  break;
+  default:
+    rtems_rtl_set_error (EINVAL,
+                         "%s: Unsupported relocation type %ld "
+                         "in non-PLT relocations",
+                         sect->name, (uint32_t) ELF_R_TYPE(rela->r_info));
+    return rtems_rtl_elf_rel_failure;
+rtems_rtl_elf_relocate_rela (rtems_rtl_obj*            obj,
+  return rtems_rtl_elf_reloc_rela (obj,
+                                   rela,
+                                   sect,
+                                   symname,
+                                   syminfo,
+                                   symvalue,
+                                   false);
+rtems_rtl_elf_relocate_rela_tramp (rtems_rtl_obj*            obj,
+                                   rela,
+                                   sect,
+                                   symname,
+                                   syminfo,
+                                   symvalue,
+                                   true);
+rtems_rtl_elf_relocate_rel (rtems_rtl_obj*      obj,
+  rtems_rtl_set_error (EINVAL, "rel type record not supported");
+bool
+rtems_rtl_elf_unwind_parse (const rtems_rtl_obj* obj,
+                            const char*          name,
+                            uint32_t             flags) {
+  return rtems_rtl_elf_unwind_dw2_parse (obj, name, flags);
+bool
+rtems_rtl_elf_unwind_register (rtems_rtl_obj* obj) {
+  return rtems_rtl_elf_unwind_dw2_register (obj);
+bool
+rtems_rtl_elf_unwind_deregister (rtems_rtl_obj* obj) {
+  return rtems_rtl_elf_unwind_dw2_deregister (obj);
diff --git a/cpukit/score/cpu/riscv/include/machine/elf_machdep.h b/cpukit/score/cpu/riscv/include/machine/elf_machdep.h
index 0000000000..84220b8271
--- /dev/null
+++ b/cpukit/score/cpu/riscv/include/machine/elf_machdep.h
@@ -0,0 +1,144 @@
+/* $NetBSD: elf_machdep.h,v 1.6 2017/11/06 03:47:48 christos Exp $ */
+ * Copyright (c) 2014 The NetBSD Foundation, Inc.
+ * All rights reserved.
+ * This code is derived from software contributed to The NetBSD Foundation
+ * by Matt Thomas of 3am Software Foundry.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE NETBSD FOUNDATION, INC. AND CONTRIBUTORS
+ * ``AS IS'' AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
+ * TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
+ * PURPOSE ARE DISCLAIMED.  IN NO EVENT SHALL THE FOUNDATION OR CONTRIBUTORS
+ * BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+#ifndef _RISCV_ELF_MACHDEP_H_
+#define _RISCV_ELF_MACHDEP_H_
+#define EM_RISCV                243
+#define	ELF32_MACHDEP_ID		EM_RISCV
+#define	ELF64_MACHDEP_ID		EM_RISCV
+#define ELF32_MACHDEP_ENDIANNESS	ELFDATA2LSB
+#define ELF64_MACHDEP_ENDIANNESS	ELFDATA2LSB
+#define ELF32_MACHDEP_ID_CASES		\
+		case EM_RISCV:		\
+			break;
+#define	ELF64_MACHDEP_ID_CASES		\
+		case EM_RISCV:		\
+			break;
+#define	KERN_ELFSIZE		32
+#ifdef _LP64
+#define ARCH_ELFSIZE		64	/* MD native binary size */
+#else
+#define ARCH_ELFSIZE		32	/* MD native binary size */
+#endif
+/* Processor specific flags for the ELF header e_flags field.  */
+/* Processor specific relocation types */
+#define R_RISCV_NONE		0
+#define R_RISCV_32		1	// A
+#define R_RISCV_64		2
+#define R_RISCV_RELATIVE	3
+#define R_RISCV_COPY		4
+#define R_RISCV_JMP_SLOT	5
+#define R_RISCV_TLS_DTPMOD32	6
+#define R_RISCV_TLS_DTPREL32	7
+#define R_RISCV_TLS_DTPMOD64	8
+#define R_RISCV_TLS_DTPREL64	9
+#define R_RISCV_TLS_TPREL32	10
+#define R_RISCV_TLS_TPREL64	11
+/* The rest are not used by the dynamic linker */
+#define R_RISCV_BRANCH		16	// (A - P) & 0xffff
+#define R_RISCV_JAL		17	// A & 0xff
+#define R_RISCV_CALL		18	// (A - P) & 0xff
+#define R_RISCV_CALL_PLT	19
+#define R_RISCV_GOT_HI20	20
+#define R_RISCV_TLS_GOT_HI20	21
+#define R_RISCV_TLS_GD_HI20	22
+#define R_RISCV_PCREL_HI20	23
+#define R_RISCV_PCREL_LO12_I	24
+#define R_RISCV_PCREL_LO12_S	25
+#define R_RISCV_HI20		26	// A & 0xffff
+#define R_RISCV_LO12_I		27	// (A >> 16) & 0xffff
+#define R_RISCV_LO12_S		28	// (S + A - P) >> 2
+#define R_RISCV_TPREL_HI20	29
+#define R_RISCV_TPREL_LO12_I	30
+#define R_RISCV_TPREL_LO12_S	31
+#define R_RISCV_TPREL_ADD	32
+#define R_RISCV_ADD8		33
+#define R_RISCV_ADD16		34
+#define R_RISCV_ADD32		35
+#define R_RISCV_ADD64		36
+#define R_RISCV_SUB8		37
+#define R_RISCV_SUB16		38
+#define R_RISCV_SUB32		39
+#define R_RISCV_SUB64		40
+#define R_RISCV_GNU_VTINHERIT	41	// A & 0xffff
+#define R_RISCV_GNU_VTENTRY	42
+#define R_RISCV_ALIGN		43
+#define R_RISCV_RVC_BRANCH	44
+#define R_RISCV_RVC_JUMP	45
+#define R_RISCV_RVC_LUI   46
+#define R_RISCV_RELAX       51
+#define R_RISCV_SUB6        52
+#define R_RISCV_SET6        53
+#define R_RISCV_SET8        54
+#define R_RISCV_SET16       55
+#define R_RISCV_SET32       56
+#define R_RISCV_32_PCREL    57
+/* These are aliases we can use R_TYPESZ */
+#define R_RISCV_ADDR32		R_RISCV_32
+#define R_RISCV_ADDR64		R_RISCV_64
+#define R_TYPE(name)		R_RISCV_ ## name
+#if ELFSIZE == 32
+#define R_TYPESZ(name)		R_RISCV_ ## name ## 32
+#else
+#define R_TYPESZ(name)		R_RISCV_ ## name ## 64
+#endif
+#ifdef _KERNEL
+#ifdef ELFSIZE
+#define ELF_MD_PROBE_FUNC       ELFNAME2(cpu_netbsd,probe)
+#endif
+struct exec_package;
+int cpu_netbsd_elf32_probe(struct lwp *, struct exec_package *, void *, char *,
+        vaddr_t *);
+int cpu_netbsd_elf64_probe(struct lwp *, struct exec_package *, void *, char *,
+        vaddr_t *);
+#endif /* _KERNEL */
+#endif /* _RISCV_ELF_MACHDEP_H_ */
diff --git a/testsuites/libtests/configure.ac b/testsuites/libtests/configure.ac
index 4d0707c219..f3a1cd586d 100644
--- a/testsuites/libtests/configure.ac
+++ b/testsuites/libtests/configure.ac
@@ -51,7 +51,7 @@ AM_CONDITIONAL(HAS_POSIX,test x"${rtems_cv_RTEMS_POSIX_API}" = x"yes")
 # Must match the list in cpukit.
 case $RTEMS_CPU in
    TEST_LIBDL=yes ;;
   bfin)
2.17.1
