psxfenv01 fails to compile for SPARC and I guess many others
Sebastian Huber
Mon Nov 11 14:10:23 UTC 2019
Hello,
I get a compile error even with the latest Newlib:
/home/EB/sebastian_h/git-rtems-5/c/src/../../testsuites/psxtests/psxfenv01/init.c:
In function 'Init':
/home/EB/sebastian_h/git-rtems-5/c/src/../../testsuites/psxtests/psxfenv01/init.c:97:23:
error: 'FE_DIVBYZERO' undeclared (first use in this function); did you
mean 'FD_ZERO'?
r = feraiseexcept(FE_DIVBYZERO);
FD_ZERO
note: each undeclared identifier is reported only once for each function
it appears in
This define is commented out:
/build/rtems/5/powerpc-rtems5/include/sys/fenv.h: * FE_DIVBYZERO
/build/rtems/5/powerpc-rtems5/include/sys/fenv.h://#define FE_DIVBYZERO
0x00000001
//(FE_DIVBYZERO|FE_INEXACT|FE_INVALID|FE_OVERFLOW|FE_UNDERFLOW)
/build/rtems/5/arm-rtems5/include/sys/fenv.h: * FE_DIVBYZERO
/build/rtems/5/arm-rtems5/include/sys/fenv.h://#define FE_DIVBYZERO
0x00000001
/build/rtems/5/sparc-rtems5/include/sys/fenv.h: * FE_DIVBYZERO
/build/rtems/5/sparc-rtems5/include/sys/fenv.h://#define FE_DIVBYZERO
0x00000001
/build/rtems/5/riscv-rtems5/include/sys/fenv.h:#define FE_DIVBYZERO
0x00000008
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
