[PATCH] eng: Add build system chapter
Tue Nov 12 06:05:51 UTC 2019
On 11/11/2019 23:29, Chris Johns wrote:
> On 11/11/19 8:45 pm, Sebastian Huber wrote:
>> On 08/11/2019 23:48, Chris Johns wrote:[...]
>>> 3. Is the ${} expansion something you have implemented? It is a nice feature.
>> With standard Python the substitution itself is a one liner:
>>      def substitute(self, ctx, value):
>>          if isinstance(value, str):
>>              try:
>>                  return Template(value).substitute(ctx.env)
>>              except Exception as e:
>>                  ctx.fatal(
>>                      "In item '{}' substitution in '{}' failed: {}".format(
>>                          self.uid, value, e
>>          return value
> Does this support nested defines?
You mean something like this:
Python 2.7.14 (default, Oct 12 2017, 15:50:02) [GCC] on linux2
Type "help", "copyright", "credits" or "license" for more information.
 >>> import string
 >>> d={"a":"x","b":"y","c":"${a}${b}"}
 >>> t=string.Template("${c}")
 >>> t.substitute(d)
'${a}${b}'
Apparently, the Template.substitute() doesn't work recursively.
The variables used for the substitution are the configuration set
environment variables. I intentionally didn't add a recursive
substitution since you should specify the variable definitions in a
proper order.
> The RSB and rtemstoolkit macros recursively expand as it was a something I found
> needed and useful ...
> https://git.rtems.org/rtems-tools/tree/rtemstoolkit/macros.py#n471
I think we should keep it simple in the build system right now. If there
is a real need, then we can have a look at this.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
