[PATCH v5] riscv: add freedom E310 Arty A7 bsp
Thu Nov 14 13:49:05 UTC 2019
On Thu, Nov 14, 2019 at 7:21 AM Sebastian Huber <
> On 14/11/2019 14:07, Joel Sherrill wrote:
> > On Wed, Oct 23, 2019, 1:16 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     Hello Pragnesh,
> >     thanks for your contribution. I checked in the patch without the
> >     frdme310arty.dts file. It had no license information and I think it
> is
> >     not needed by the BSP directly. I guess a boot loader will provide
> the
> >     device tree?
> > But the bsp is not functional without it so can't be tested. How does
> > this file get used on the real board?
> > If the license question is answered, we need a long term solution as to
> > its location. We shouldn't send users on a chase for a file which could
> > disappear because we don't have it.
> > Also can this run on a simulator with this or a similar device tree?
> The device trees are provided by the boot loader. If I understood this
> correctly, then RTEMS is started by a boot loader on the Freedom E310
> Arty A7?
To be pedantic, is this the board?
https://www.digikey.com/eewiki/display/LOGIC/Digilent+Arty+A7+with+Xilinx+Artix-7+Implementing+SiFive+FE310+RISC-V
Are there any accessories or JTAG you need? If you have a JTAG adapter you
know works,
please pass that along.
How different are the instructions there from what would be required when
using RTEMS?
I don't recall. Did you post test results?
Did you look at the performance at all? There are no known performance
issues but
always worth asking.
I'm thrilled to see this merged and available. Just wanting to ease the
startup for using
RTEMS on it.
Thanks
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191114/b1e2d294/attachment.html>
