[PATCH v2] Add TOD Hooks to allow BSP to take action when TOD is set
Sebastian Huber
Fri Nov 15 05:59:32 UTC 2019
On 14/11/2019 21:44, Joel Sherrill wrote:
> +bool _TOD_Hook_Register(
> + TOD_Hook *hook
> + ISR_lock_Context lock_context;
> + * At this time, this method does NOT have a Classic or POSIX API
> + * that exports it. Any use of this method will be a direct call.
> + * It should only be called while NOT holding the TOD lock.
> + _Assert( !_TOD_Is_owner() );
> + if ( hook == NULL ) {
> + return FALSE;
> + _TOD_Lock();
> + _TOD_Acquire( &lock_context );
> + _Chain_Append_unprotected( &_TOD_Hooks, &hook->Node );
> + _TOD_Unlock();
> + return true;
Where is the _TOD_Release()? This function should not test for a NULL
hook and return void. Such kind of error handling should be done by
upper layer functions and not at the lowest level.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
