[PATCH 2/4] rtems: Fix kernel and tools release source package selection.
chrisj at rtems.org chrisj at rtems.org
Sun Nov 17 22:01:00 UTC 2019
Closes #3814
 rtems/config/tools/rtems-kernel-common.cfg |  9 ++++-----
 rtems/config/tools/rtems-libbsd-5.cfg      |  6 ++++--
 rtems/config/tools/rtems-libbsd-common.cfg |  9 +++++++--
 rtems/config/tools/rtems-tools-5-1.cfg     | 11 ++++++++---
 4 files changed, 23 insertions(+), 12 deletions(-)
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 6e8cf32..6749937 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -114,12 +114,10 @@ URL: 	 https://www.rtems.org/
 # Source
 %if %{rsb_released}
- %if ! %{defined rtems_kernel_compression}
-  %define rtems_kernel_compression xz
- %endif
- %define rtems_kernel_version %{rtems_version}
+ %define rtems_kernel_file rtems-%{rtems_kernel_version}.tar.xz
  %define rtems_bootstrap 0
 %else
+ %define rtems_kernel_file rtems-kernel-%{rtems_kernel_version}.tar.xz
  # The code in git needs to be bootstrapped. Do each build because we have
  # no way to change what changes may have happened in the code.
@@ -131,7 +129,8 @@ URL: 	 https://www.rtems.org/
  %error No RTEMS kernel version defined
 %endif
-%source set rtems_kernel --rsb-file=rtems-kernel-%{rtems_kernel_version}.tar.bz2 https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
+%source set rtems_kernel --rsb-file=%{rtems_kernel_file} \
+              https://git.rtems.org/rtems/snapshot/rtems-%{rtems_kernel_version}.tar.bz2
 # If C++ defined for the tool set use it to control RTEMS's setting..
diff --git a/rtems/config/tools/rtems-libbsd-5.cfg b/rtems/config/tools/rtems-libbsd-5.cfg
index d6157d1..3e3888d 100644
--- a/rtems/config/tools/rtems-libbsd-5.cfg
+++ b/rtems/config/tools/rtems-libbsd-5.cfg
@@ -3,9 +3,11 @@
 %define rtems_libbsd_version 791ea27c8d5c0291c5aa8c4ddd373f7adbe8414a
-%hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 husSxTd2f4cnxR/opNX95z50EjeZlfL22r7/eAvzupSXLxm1fcNz+xKU8vBVyaIKtc34MPK5nvvoqHPPXnzGkQ==
+%hash sha512 rtems-libbsd-%{rtems_libbsd_version}.tar.bz2 \
+              husSxTd2f4cnxR/opNX95z50EjeZlfL22r7/eAvzupSXLxm1fcNz+xKU8vBVyaIKtc34MPK5nvvoqHPPXnzGkQ==
 %define rtems_waf_version ad6c6e8771b95dffa73a7dc1167d98d208f17cb0
-%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 9866ab0772cbd3aa4e641a14fad2c85acf79d8e6e08de05c32e985bb76b9f04a0a615093320b406ff4660ec1964f2c0778453b44a8b1358c6f04ccd7561cad1c
+%hash sha512 rtems-waf-%{rtems_waf_version}.tar.bz2 \
+              9866ab0772cbd3aa4e641a14fad2c85acf79d8e6e08de05c32e985bb76b9f04a0a615093320b406ff4660ec1964f2c0778453b44a8b1358c6f04ccd7561cad1c
 # The RTEMS LibBSD build instructions.
diff --git a/rtems/config/tools/rtems-libbsd-common.cfg b/rtems/config/tools/rtems-libbsd-common.cfg
index f5f78f2..1cea6b7 100644
--- a/rtems/config/tools/rtems-libbsd-common.cfg
+++ b/rtems/config/tools/rtems-libbsd-common.cfg
@@ -20,6 +20,9 @@ URL:       https://git.rtems.org/rtems-libbsd.git/
 %if %{rsb_released}
  %define rtems_libbsd_version %{rsb_version}
+ %define rtems_libbsd_ext xz
+%else
+ %define rtems_libbsd_ext bz2
 %endif
@@ -34,8 +37,10 @@ URL:       https://git.rtems.org/rtems-libbsd.git/
 #  which is a good thing because we would collect the entire FreeBSD source
-%source set rtems_libbsd https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.bz2
-%source set rtems_waf    https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.bz2
+%source set rtems_libbsd \
+      https://git.rtems.org/rtems-libbsd/snapshot/rtems-libbsd-%{rtems_libbsd_version}.tar.%{rtems_libbsd_ext}
+%source set rtems_waf \
+      https://git.rtems.org/rtems_waf/snapshot/rtems_waf-%{rtems_waf_version}.tar.%{rtems_libbsd_ext}
 # Prepare the source code.
diff --git a/rtems/config/tools/rtems-tools-5-1.cfg b/rtems/config/tools/rtems-tools-5-1.cfg
index 459d9fe..c633093 100644
--- a/rtems/config/tools/rtems-tools-5-1.cfg
+++ b/rtems/config/tools/rtems-tools-5-1.cfg
@@ -7,13 +7,18 @@
 %if %{rsb_released}
  %define rtems_tools_version %{rsb_version}
+ %define rtems_tools_source rtems-tools-%{rtems_tools_version}
+ %define rtems_tools_ext xz
 %else
  %define rtems_tools_version 12bd8f77bad4779319039fd7be33d006e10f5618
- %define rtems_tools_source rtems-tools-%{rtems_tools_version}
- %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.bz2
- %hash sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 d720966bee1cd7f4484cadfbc8bad2ac0d74e07912df0b66f900a959e652d18080157e31c957ca0c9a4f0d8bec99dcc0b7c06e61a62b955ef230d9630f6fe111
+ %define rtems_tools_ext bz2
 %endif
+%define rtems_tools_source rtems-tools-%{rtems_tools_version}
+%source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
+%hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
+         1yCWa+4c1/RITK37yLrSrA104HkS3wtm+QCpWeZS0YCAFX4xyVfKDJpPDYvsmdzAt8BuYaYrlV7yMNljD2/hEQ==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.19.1
