[PATCH 4/4] rtems/kernel: Fix the git download extension for the kernel.
chrisj at rtems.org chrisj at rtems.org
Sun Nov 17 22:01:02 UTC 2019
 rtems/config/tools/rtems-kernel-common.cfg | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/rtems/config/tools/rtems-kernel-common.cfg b/rtems/config/tools/rtems-kernel-common.cfg
index 6749937..dfb12c6 100644
--- a/rtems/config/tools/rtems-kernel-common.cfg
+++ b/rtems/config/tools/rtems-kernel-common.cfg
@@ -117,7 +117,7 @@ URL: 	 https://www.rtems.org/
  %define rtems_kernel_file rtems-%{rtems_kernel_version}.tar.xz
  %define rtems_bootstrap 0
 %else
- %define rtems_kernel_file rtems-kernel-%{rtems_kernel_version}.tar.xz
+ %define rtems_kernel_file rtems-kernel-%{rtems_kernel_version}.tar.bz2
  # The code in git needs to be bootstrapped. Do each build because we have
  # no way to change what changes may have happened in the code.
2.19.1
