[PATCH 2/3] tar01 and tar02: Do not generate tar archives
Sebastian Huber
Tue Nov 19 06:19:36 UTC 2019
On 19/11/2019 02:15, Chris Johns wrote:
> On 18/11/19 6:10 pm, Sebastian Huber wrote:
>> This simplifies the build and avoids some host dependencies, e.g.
>> availability of symbolic links in the host file system. Makes it
>> possible to validate time stamps.
>> Update #3818.
>> testsuites/libtests/Makefile.am | 41 ++++++++-------------------------
>> testsuites/libtests/tar01/tar01.tar | Bin 0 -> 10240 bytes
>> testsuites/libtests/tar01/tar01.tar.gz | Bin 0 -> 296 bytes
>> testsuites/libtests/tar01/tar01.tar.xz | Bin 0 -> 340 bytes
>> testsuites/libtests/tar02/tar02.tar | Bin 0 -> 10240 bytes
>> 5 files changed, 9 insertions(+), 32 deletions(-)
>> create mode 100644 testsuites/libtests/tar01/tar01.tar
>> create mode 100644 testsuites/libtests/tar01/tar01.tar.gz
>> create mode 100644 testsuites/libtests/tar01/tar01.tar.xz
>> create mode 100644 testsuites/libtests/tar02/tar02.tar
> How are the tar files created?
I copied the files from my build tree to the source tree.
> How do we capture what is in them and how to regenerate them?
Ok, this is an issue. You have to unpack them, change your stuff, and
re-create them by hand.
> At the moment I
> can inspect all of this test via cgit. The idea of downloading and checking can
> be problematic depending on the host and set up, ie a tablet.
> Has the generation of these files been checked on more than Linux?
I doubt that anyone did run the tests using a FAT file system on the
host for example.
> How do we check updated host tools have not broken the code we have in RTEMS?
I would consider it a serious bug in a future host pax tool if it breaks
the RTEMS code.
> I am concerned we are loosing some of the checking that we currently have moving
> to this approach. The symlink issue is a real one so maybe we hold a single tar
> to check that works.
With the dynamic generation of the archive we cannot test the file
permissions, the group and user IDs, and the time stamps.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
