dl06
Jonathan Brandmeyer
jbrandmeyer at planetiq.com
Wed Nov 20 06:05:47 UTC 2019
On Tue, Nov 19, 2019 at 5:13 PM Chris Johns <chrisj at rtems.org> wrote:
> On 19/11/19 5:36 pm, Sebastian Huber wrote:
> > On 19/11/2019 01:59, Chris Johns wrote:
> >> On 18/11/19 7:12 pm, Sebastian Huber wrote:
> >> I am fine with tar being used if configure magic is used to select it.
> This may
> >> expose RTEMS tar support bugs, I cannot remember now.
> > Is tar supported by RTEMS? The last time I tried to use didn't work as
> far as I
> > remember. Maybe it is related to our two independent untar solutions
> > (<rtems/untar.h> and rtems_tarfs_load()).
> I am using it in some applications but I cannot remember how so I suppose
> the
> answer is yes. Joel reminded me yesterday it was ustar or something like
> that
> which has caused us problems.
Since you mentioned it, https://devel.rtems.org/ticket/3823
RTEMS untar doesn't properly handle nested directories. foo/bar.txt
unpacks just fine, but foo/bar/baz.txt doesn't, unless foo/ exists first.
Jonathan Brandmeyer
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191119/783f90a4/attachment.html>
