[PATCH 2/3] tar01 and tar02: Do not generate tar archives
Wed Nov 20 14:39:56 UTC 2019
On 20/11/2019 00:52, Chris Johns wrote:
>>> I am concerned we are loosing some of the checking that we currently have moving
>>> to this approach. The symlink issue is a real one so maybe we hold a single tar
>>> to check that works.
>> With the dynamic generation of the archive we cannot test the file permissions,
>> the group and user IDs, and the time stamps.
> Ah yes this is a good point. Could we have a single tar file that tests those
> parts and others that are generated to test the host and RTEMS code?
At the moment my only concern is the new build system. I have to focus
to get this integrated since I don't want to reiterate the conversion
due to changes in the RTEMS sources which may take place in the meantime.
There are some issues with waf and pax. Waf doesn't like directories as
nodes. You have to use files. If you only feed files into pax, you end
up with:
$ tar tf build/sparc/erc32/testsuites/libtests/tar01/tar01.tar
home/test_file
home/test_script
symlink
Which leads to:
https://devel.rtems.org/ticket/3823
I think we have to fix our tar support first to make any progress here.
This will delay my build system work and I am currently very busy with
other things. The question is if we should start integrating it without
the tests which depend on tar.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
