[PATCH] tester: Add basic support to generate JUnit test reports
Hesham Almatary
Hesham.Almatary at cl.cam.ac.uk
Wed Nov 20 15:01:07 UTC 2019
tester/rt/test.py | 29 ++++++++++++++++++++++++++++-
1 file changed, 28 insertions(+), 1 deletion(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 3cd9b48..db83b77 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -285,8 +285,35 @@ def generate_json_report(args, reports, start_time, end_time,
json.dump(json_log, outfile, sort_keys=True, indent=4)
+def generate_junit_report(args, reports, start_time, end_time,
+ total, junit_file):
+ from junit_xml import TestSuite, TestCase
+ import sys
+ junit_log = []
+ for name in reports.results:
+ result_type = reports.results[name]['result']
+ test_parts = name.split("/")
+ test_category = test_parts[-2]
+ test_name = test_parts[-1]
+ junit_result = TestCase(test_name.split('.')[0])
+ junit_result.category = test_category
+ if result_type == "failed" or result_type == "timeout":
+ junit_result. add_failure_info(None, reports.results[name]["output"], result_type)
+ junit_log.append(junit_result)
+ ts = TestSuite("RTEMS Test Suite", junit_log)
+ # write out junit log
+ with open(junit_file, 'w') as f:
+ TestSuite.to_file(f, [ts], prettyprint=True)
report_formatters = {
- 'json': generate_json_report
+ 'json': generate_json_report,
+ 'junit': generate_junit_report
2.17.1
