[PATCH] bsp-howto/miscellanous_support.rst: Fix grammar mistake.
Joel Sherrill
joel at rtems.org
Fri Nov 22 17:27:54 UTC 2019
bsp-howto/miscellanous_support.rst | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/bsp-howto/miscellanous_support.rst b/bsp-howto/miscellanous_support.rst
index 77b7194..efb4454 100644
--- a/bsp-howto/miscellanous_support.rst
+++ b/bsp-howto/miscellanous_support.rst
@@ -307,7 +307,7 @@ required to be writen by the BSP developer are :
.. index:: bsp_interrupt_dispatch()
-- ``bsp_interrupt_dispatch()`` service the ISR by handling any bsp specific
+- ``bsp_interrupt_dispatch()`` services the ISR by handling any bsp specific
code & calling the generic method ``bsp_interrupt_handler_dispatch()`` which
in turn services the interrupt by running the ISR after looking it up in the
table. It acts as an entry to the interrupt switchboard, since the bsp
1.8.3.1
