[PATCH] psxinttypes01: Remove invalid test cases
Joel Sherrill
joel at rtems.org
Mon Nov 25 12:45:24 UTC 2019
The scn file will be incorrect after this change. The doc file may be as
well.
On Mon, Nov 25, 2019, 2:40 AM Sebastian Huber <
> The functions expect a valid string as input according to POSIX. On
> systems with a NULL pointer protection the test cases ended up in
> exceptions.
> testsuites/psxtests/psxinttypes01/init.c | 20 --------------------
> 1 file changed, 20 deletions(-)
> diff --git a/testsuites/psxtests/psxinttypes01/init.c
> b/testsuites/psxtests/psxinttypes01/init.c
> index bfb6d4b357..030aa2aa57 100644
> --- a/testsuites/psxtests/psxinttypes01/init.c
> +++ b/testsuites/psxtests/psxinttypes01/init.c
> @@ -95,11 +95,6 @@ rtems_task Init(rtems_task_argument ignored)
> rtems_test_assert( result_strtoimax == INTMAX_MIN );
> rtems_test_assert( errno == ERANGE );
> - puts( "Invalid Input - Send NULL Pointer" );
> - result_strtoimax = strtoimax( NULL, &endptr1, base );
> - rtems_test_assert( result_strtoimax == 0 );
> - rtems_test_assert( errno == EINVAL );
> puts( "Invalid Input - Invalid base - Use base = 40" );
> result_strtoimax = strtoimax( nptr1_p, &endptr1, invalid_base );
> @@ -131,11 +126,6 @@ rtems_task Init(rtems_task_argument ignored)
> rtems_test_assert( result_strtoumax != 0 );
> - result_strtoumax = strtoumax( NULL, &endptr1, base );
> - rtems_test_assert( result_strtoumax == 0 );
> result_strtoumax = strtoumax( nptr1_p, &endptr1, invalid_base );
> @@ -167,11 +157,6 @@ rtems_task Init(rtems_task_argument ignored)
> - result_strtoimax = wcstoimax( NULL, &endptr2, base );
> result_strtoimax = wcstoimax( nptr2_p, &endptr2, invalid_base );
> @@ -203,11 +188,6 @@ rtems_task Init(rtems_task_argument ignored)
> - result_strtoumax = wcstoumax( NULL, &endptr2, base );
> result_strtoumax = wcstoumax( nptr2_p, &endptr2, invalid_base );
> 2.16.4
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191125/8f690da6/attachment.html>
