[PATCH] user: Add frdme310arty BSP varient
Pragnesh Patel pragnesh.patel at sifive.com
Fri Nov 29 07:42:46 UTC 2019
Signed-off-by: Pragnesh Patel <pragnesh.patel at sifive.com>
 user/bsps/bsps-riscv.rst | 8 ++++++++
 1 file changed, 8 insertions(+)
diff --git a/user/bsps/bsps-riscv.rst b/user/bsps/bsps-riscv.rst
index c3ca098..0799ad6 100644
--- a/user/bsps/bsps-riscv.rst
+++ b/user/bsps/bsps-riscv.rst
@@ -36,6 +36,8 @@ This BSP offers 13 variants:
 * rv64imafdc_medany
+* frdme310arty
 Each variant corresponds to a GCC multilib.  A particular variant reflects an
 ISA with ABI and code model choice.
@@ -87,6 +89,10 @@ The following options are available at the configure command line.
 ``RISCV_RAM_REGION_SIZE``
      The size of the RAM region for linker command file (default 64MiB).
+``RISCV_ENABLE_FRDME310ARTY_SUPPORT``
+     Enables support sifive Freedom E310 Arty board if defined to a non-zero
+     value,otherwise it is disabled (disabled by default)
 Interrupt Controller
@@ -111,6 +117,8 @@ The console driver supports devices compatible to
 * "ns16750" (see ``RISCV_CONSOLE_MAX_NS16550_DEVICES`` BSP option).
+* "sifive,uart0" (see ``RISCV_ENABLE_FRDME310ARTY_SUPPORT`` BSP option).
 They are initialized according to the device tree.  The console driver does not
 configure the pins or peripheral clocks.  The console device is selected
 according to the device tree "/chosen/stdout-path" property value.
2.17.1
