[PATCH] user: Document patch review process
Sebastian Huber
Tue Oct 1 05:50:03 UTC 2019
On 01/10/2019 01:40, Chris Johns wrote:
> On 30/9/19 10:45 pm, Sebastian Huber wrote:
>> images/user/patch-review.png | Bin 0 -> 57130 bytes
>> images/user/patch-review.puml | 44 +++++++++++++++++++++++++++
>> user/support/contrib.rst | 67 +++++++++++++++++++++++++++++++++---------
>> 3 files changed, 97 insertions(+), 14 deletions(-)
>> create mode 100644 images/user/patch-review.png
>> create mode 100644 images/user/patch-review.puml
> If you want to review the figure it is ...
> http://www.plantuml.com/plantuml/png/dP0_ZzDC4CRx_HGZwoqIlSf9K8Q28451ST7f3WgaD7lsutZ1EsjcnuxoxLcFWt9790gAbNR-_6QUUNPPlUWOU-VivzpsWuZd8-YSHg6wc_-P0X_OCy7dCsaYmHHm8i_DWUlKGS1AWzUwemm9oE_AeCyyfH_OKbKTWrAR97hTM5DLpVKdS4FQuHKuJsymeT-98kQx9CSPlMnSCANztFQsHASkzA3LerKXkR2ng7gX-sR3-pM5JAjlo6j7jFsOh4FmSmo2AsbJ15v1dXYdFyyhwDUXcSjrYZ4eHUJiZQph94tWOt-slhyOGPk9_jkR7IQb7YDOJT1l7QsaI1CaXyJBtNlwdzuS-DLfxMo3RnLYoMgpsLJK1uPDDi-khEN-pVx2N2pVfxLpeQNLmqlyvEr-38g6diyN3b9SdtVnrVU7CNStwm-iQKbA-evQIJ2a73J9OYKd1KauTbe2elinAps3ciIOjtcszEENJ_TF57rWBGzoLxBWncY7FY_gpV6GQo-tDjYXeNKkQngSsvLeZFql
Nice, you can use it for new images here:
http://www.plantuml.com/plantuml/uml/SyfFKj2rKt3CoKnELR1Io4ZDoSa70000
>> +* The patch builds. All RTEMS tests link with this patch.
>> +* The patch does not introduce new compiler warnings.
> This step is not in the figure.
You mean there should be a step mentioning this checklist?
> Built against which BSPs?
This is for the user manual. I think at least one arbitrary BSP which is
affected by the patch should be sufficient.
>> +* The patch does not introduce new test failures in existing tests.
> Again which BSPs? This assumes expected fails are valid for the bsps being tested.
I think we should not add to many details to the figure.
> What about tickets and the "Closes ...", "Updates ..." etc tags?
Yes, this is missing. What should be checked as well?
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
