[PATCH 1/3] libtest: Do all output in test runner
Sebastian Huber
Tue Oct 1 13:20:01 UTC 2019
This ensures that lines are output atomically if they are produced by
different other contexts, e.g. interrupts, other processors, other
threads.
Update #3199.
cpukit/include/t.h | 2 +
cpukit/libtest/t-test.c | 138 ++++++++++++++++++++++++++++++-------
testsuites/libtests/ttest01/init.c | 4 ++
3 files changed, 121 insertions(+), 23 deletions(-)
diff --git a/cpukit/include/t.h b/cpukit/include/t.h
index c5e3792ec1..5dbf1e00b5 100644
--- a/cpukit/include/t.h
+++ b/cpukit/include/t.h
@@ -2199,6 +2199,8 @@ typedef void (*T_putchar)(int, void *);
typedef struct {
const char *name;
+ char *buf;
+ size_t buf_size;
T_putchar putchar;
void *putchar_arg;
T_verbosity verbosity;
diff --git a/cpukit/libtest/t-test.c b/cpukit/libtest/t-test.c
index cf3bcd6a99..881a92efb0 100644
--- a/cpukit/libtest/t-test.c
+++ b/cpukit/libtest/t-test.c
@@ -47,12 +47,16 @@
#include "t-test-printf.h"
#endif /* __rtems__ */
-#define T_LINE_SIZE 120
+#define T_LINE_SIZE 128
#define T_SCOPE_SIZE 5
typedef struct {
pthread_spinlock_t lock;
+ char *buf;
+ unsigned int buf_mask;
+ atomic_uint buf_head;
+ atomic_uint buf_tail;
void (*putchar)(int, void *);
void *putchar_arg;
@@ -81,18 +85,6 @@ typedef struct {
static T_context T_instance;
-static int
-T_do_vprintf(T_context *ctx, char const *fmt, va_list ap)
- return _IO_Vprintf(ctx->putchar, ctx->putchar_arg, fmt, ap);
-int
-T_vprintf(char const *fmt, va_list ap)
- return T_do_vprintf(&T_instance, fmt, ap);
typedef struct {
char *s;
size_t n;
@@ -101,13 +93,13 @@ typedef struct {
static void
T_putchar_string(int c, void *arg)
- T_putchar_string_context *ctx;
+ T_putchar_string_context *sctx;
char *s;
size_t n;
- ctx = arg;
- s = ctx->s;
- n = ctx->n;
+ sctx = arg;
+ s = sctx->s;
+ n = sctx->n;
if (n == 1) {
c = '\0';
@@ -119,8 +111,8 @@ T_putchar_string(int c, void *arg)
--n;
- ctx->s = s;
- ctx->n = n;
+ sctx->s = s;
+ sctx->n = n;
int
@@ -128,17 +120,106 @@ T_snprintf(char *s, size_t n, char const *fmt, ...)
va_list ap;
int len;
- T_putchar_string_context ctx = {
+ T_putchar_string_context sctx = {
.s = s,
.n = n
va_start(ap, fmt);
- len = _IO_Vprintf(T_putchar_string, &ctx, fmt, ap);
+ len = _IO_Vprintf(T_putchar_string, &sctx, fmt, ap);
va_end(ap);
- if (ctx.n > 0) {
- *ctx.s = '\0';
+ if (sctx.n > 0) {
+ *sctx.s = '\0';
+ return len;
+static int
+T_vprintf_direct(char const *fmt, va_list ap)
+ T_context *ctx;
+ unsigned int head;
+ unsigned int tail;
+ ctx = &T_instance;
+ head = atomic_load_explicit(&ctx->buf_head, memory_order_acquire);
+ tail = atomic_load_explicit(&ctx->buf_tail, memory_order_relaxed);
+ while (head != tail) {
+ (*ctx->putchar)(ctx->buf[tail], ctx->putchar_arg);
+ tail = (tail + 1) & ctx->buf_mask;
+ atomic_store_explicit(&ctx->buf_tail, tail, memory_order_relaxed);
+ return _IO_Vprintf(ctx->putchar, ctx->putchar_arg, fmt, ap);
+static int
+T_vprintf_buffered(char const *fmt, va_list ap)
+ unsigned int len;
+ T_context *ctx;
+ char buf[T_LINE_SIZE];
+ .s = buf,
+ .n = sizeof(buf)
+ unsigned int mask;
+ unsigned int capacity;
+ len = (unsigned int)_IO_Vprintf(T_putchar_string, &sctx, fmt, ap);
+ if (len >= sizeof(buf)) {
+ len = sizeof(buf) - 1;
+ pthread_spin_lock(&ctx->lock);
+ head = atomic_load_explicit(&ctx->buf_head, memory_order_relaxed);
+ mask = ctx->buf_mask;
+ capacity = (tail - head - 1) & mask;
+ if (len <= capacity) {
+ unsigned int todo;
+ char *c;
+ todo = len;
+ c = buf;
+ while (todo > 0) {
+ ctx->buf[head] = *c;
+ head = (head + 1) & mask;
+ --todo;
+ ++c;
+ atomic_store_explicit(&ctx->buf_head, head,
+ memory_order_release);
+ } else {
+ /* If it does not fit into the buffer, discard everything */
+ len = 0;
+ pthread_spin_unlock(&ctx->lock);
+ return (int)len;
+int
+T_vprintf(char const *fmt, va_list ap)
+ int len;
+ if (T_is_runner()) {
+ len = T_vprintf_direct(fmt, ap);
+ } else {
+ len = T_vprintf_buffered(fmt, ap);
return len;
@@ -604,6 +685,17 @@ T_do_run_initialize(const T_config *config)
pthread_spin_init(&ctx->lock, PTHREAD_PROCESS_PRIVATE);
ctx->config = config;
+ ctx->buf = config->buf;
+ if (config->buf_size > 0 &&
+ (config->buf_size & (config->buf_size - 1)) == 0) {
+ ctx->buf_mask = config->buf_size - 1;
+ } else {
+ ctx->buf_mask = 0;
+ atomic_store_explicit(&ctx->buf_head, 0, memory_order_relaxed);
+ ctx->buf_tail = 0;
ctx->putchar = config->putchar;
ctx->putchar_arg = config->putchar_arg;
ctx->verbosity = config->verbosity;
diff --git a/testsuites/libtests/ttest01/init.c b/testsuites/libtests/ttest01/init.c
index 51cfa8badb..135dc2b25e 100644
--- a/testsuites/libtests/ttest01/init.c
+++ b/testsuites/libtests/ttest01/init.c
@@ -138,6 +138,8 @@ now(void)
return t * SBT_1MS;
+static char buffer[512];
static const T_action actions[] = {
T_report_hash_sha256,
test_action
@@ -145,6 +147,8 @@ static const T_action actions[] = {
static const T_config config = {
.name = "ttest01",
+ .buf = buffer,
+ .buf_size = sizeof(buffer),
.putchar = test_putchar,
.putchar_arg = &test_instance,
.verbosity = T_VERBOSE,
2.16.4
