[PATCH 1/2] barrier: Remove leftover semaphore remnants
Joel Sherrill
joel at rtems.org
Tue Oct 1 23:02:23 UTC 2019
On Tue, Oct 1, 2019, 5:07 PM Gedare Bloom <gedare at rtems.org> wrote:
> On Tue, Oct 1, 2019 at 3:53 PM Gedare Bloom <gedare at rtems.org> wrote:
> > On Wed, Sep 4, 2019 at 3:36 PM Martin Erik Werner
> > <martinerikwerner at gmail.com> wrote:
> > > Remove various incorrect references to "lock" and "obtain" and to an
> > > option set which is not part of the barrier interface.
> > > It looks like the barrier documentation was started based on a copy of
> > > the semaphore documentation and these things are surviving remnants.
> > > Also remove an unfinished sentence in the barrier wait description,
> > > since the intended information is already provided in the under the
> NOTE
> > > label.
> > Thanks for your contribution! I have a few minor comments:
> > > c-user/barrier_manager.rst | 38 +++++++-------------------------------
> > > 1 file changed, 7 insertions(+), 31 deletions(-)
> > > diff --git a/c-user/barrier_manager.rst b/c-user/barrier_manager.rst
> > > index b0bf3bf..e5d69b0 100644
> > > --- a/c-user/barrier_manager.rst
> > > +++ b/c-user/barrier_manager.rst
> > > @@ -324,8 +324,7 @@ NOTES:
> > > .. _rtems_barrier_wait:
> > > -.. index:: obtain a barrier
> > > -.. index:: lock a barrier
> > > +.. index:: wait at a barrier
> > > .. index:: rtems_barrier_wait
> > > BARRIER_WAIT - Wait at a barrier
> > > @@ -356,14 +355,11 @@ DIRECTIVE STATUS CODES:
> > > DESCRIPTION:
> > > - This directive acquires the barrier specified by ``id``. The
> > > - ``RTEMS_WAIT`` and ``RTEMS_NO_WAIT`` components of the options
> parameter
> > > - indicate whether the calling task wants to wait for the barrier
> to become
> > > - available or return immediately if the barrier is not currently
> available.
> > > - With either ``RTEMS_WAIT`` or ``RTEMS_NO_WAIT``, if the current
> barrier
> > > - count is positive, then it is decremented by one and the barrier
> is
> > > - successfully acquired by returning immediately with a successful
> return
> > > - code.
> > > + This directive waits at the barrier specified by ``id``. The
> timeout
> > > + parameter specifies the maximum interval the calling task is
> willing to be
> > > + blocked waiting for the barrier. If it is set to
> ``RTEMS_NO_TIMEOUT``,
> > > + then the calling task will wait forever. If the barrier is
> available or
> > 1. "will wait forever" -> "will wait forever if it doesn't get
> > released" or something more precise, even just "may wait forever"
Will wait until the barrier is released/opened. Then add there is no option
for no wait as found in other APIs.
> 2. I'm not quite sure what "available" means in this context. Maybe
> > "open" is a better word?
> I guess "available" is the wording that has been used throughout.
> Again, probably due to inheriting from the semaphore documentation. I
> think "open/closed" is more precise when describing a barrier, but
> available is OK if it is consistently applied.
Open/closed is better. I think of a barrier as the starting gates at a
horse race. Horses arrive and wait while the gates are closed. When the
race starts, all gates are opened and the horses are released.
> I would still like the fix on #1, even though that was not introduced
> by you just copied from elsewhere, it is good to improve it at the
> same time.
> > > + the ``RTEMS_NO_WAIT`` option component is set, then timeout is
> ignored.
> > > Conceptually, the calling task should always be thought of as
> blocking when
> > > it makes this call and being unblocked when the barrier is
> released. If
> > > @@ -372,24 +368,7 @@ DESCRIPTION:
> > > callers will block except for the one which is the Nth task which
> trips the
> > > automatic release condition.
> > > - The timeout parameter specifies the maximum interval the calling
> task is
> > > - willing to be blocked waiting for the barrier. If it is set to
> > > - ``RTEMS_NO_TIMEOUT``, then the calling task will wait forever.
> If the
> > > - barrier is available or the ``RTEMS_NO_WAIT`` option component is
> set, then
> > > - timeout is ignored.
> > > NOTES:
> > > - The following barrier acquisition option constants are defined by
> RTEMS:
> > > - .. list-table::
> > > - :class: rtems-table
> > > - * - ``RTEMS_WAIT``
> > > - - task will wait for barrier (default)
> > > - * - ``RTEMS_NO_WAIT``
> > > - - task should not wait
> > > A clock tick is required to support the timeout functionality of
> this
> > > directive.
> > > @@ -399,7 +378,6 @@ NOTES:
> > > .. _rtems_barrier_release:
> > > -.. index:: wait at a barrier
> > > .. index:: release a barrier
> > > .. index:: rtems_barrier_release
> > > @@ -425,9 +403,7 @@ DIRECTIVE STATUS CODES:
> > > DESCRIPTION:
> > > This directive releases the barrier specified by id. All tasks
> waiting at
> > > - the barrier will be unblocked. If the running task's preemption
> mode is
> > > - enabled and one of the unblocked tasks has a higher priority than
> the
> > > - running task.
> > > + the barrier will be unblocked.
> > > NOTES:
> > > The calling task may be preempted if it causes a higher priority
> task to be
> > > 2.11.0
> > > _______________________________________________
> > > devel mailing list
> > > devel at rtems.org
> > > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20191001/3bd8a08b/attachment-0001.html>
